41
Is there any scripts for downloading and installing IntelliJ with JavaJDK or OpenJDK?
I don't know how I did it before using Ubuntu 12.10 but I'm now on a fresh 13.04 install and I have been looking around for an all in one script, or some scripts I can cobble together
I have the two links detailed that I think will be handy, can anyone else add to this please?
How do I install Oracle Java JDK 7?
Install Oracle Java 7 in Ubuntu via PPA Repository
Update: I have now found you can install IntelliJ through the Ubuntu software centre, so although this was a nice learning exercise for me it's not really relevant any more. Thanks to everyone that contributed.
spences10
  • 2,652
6 Answers6
78
Installing JDK
To install JDK, you can refer to help.ubuntu.com/community/Java.
If you want to install openJDK,
sudo apt-get install openjdk-7-jdk
If you want to install Oracle JDK, you can use PPA from webup8 team.
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java7-installer
Installing IntelliJ IDEA
[Updated Answer]
Download IntelliJ IDEA CE from www.jetbrains.com/idea/download/.
  1. Extract ideaIC-XX.Y.Z.tar.gz using
    tar -zxvf ideaIC-XX.Y.Z.tar.gz
  2. Run idea.sh in bin directory inside the extracted folder.
  3. To create command-line runner, Tools > Create Command-line Launcher
  4. To create a desktop entry, Tools > Create Desktop Entry
That's it. Now, you can launch IntelliJ from Ubuntu dash.
[Old Answer]
  2. Become root.
    sudo -i
  3. Move the extracted folder to /opt/idea
    mv ideaIC-XX.Y.Z /opt/idea
  4. Create a desktop file and install it:
    gedit idea.desktop
    and copy the following to the idea.desktop file.
    [Desktop Entry]
    Name=IntelliJ IDEA
    Type=Application
    Exec=idea.sh
    Terminal=false
    Icon=idea
    Comment=Integrated Development Environment
    NoDisplay=false
    Categories=Development;IDE;
    Name[en]=IntelliJ IDEA
    then execute the following command to automatically install it in the unity:
    desktop-file-install idea.desktop
  5. Create a symlink in /usr/local/bin using
    cd /usr/local/bin
    ln -s /opt/idea/bin/idea.sh
  6. For idea icon to be displayed in dash, idea icon can be added as
    cp /opt/idea/bin/idea.png /usr/share/pixmaps/idea.png
29
This should get you started:
#!/bin/sh
add-apt-repository ppa:webupd8team/java &&
apt-get update &&
apt-get install oracle-java7-installer &&
echo oracle-java7-installer shared/accepted-oracle-license-v1-1 select true | sudo /usr/bin/debconf-set-selections &&
update-java-alternatives -s java-7-oracle &&
wget -O /tmp/intellij.tar.gz http://download.jetbrains.com/idea/ideaIC-12.0.4.tar.gz &&
tar xfz /tmp/intellij.tar.gz &&
cd idea-IC-123.169/bin &&
./idea.sh
Some things you should consider:
  • I'm not sure at which part the echo oracle-java7-installer shared/accepted-oracle-license-v1-1 select true | sudo /usr/bin/debconf-set-selections has to be. Might be a line earlier.
  • The line cd idea-IC-123.169/bin is dependend on the IntelliJ version, as the extracted folder is named in that way. It only works with the version available while I'm writing this.
  • Same goes for the download link. It might change with a newer version.
  • I'm not sure what happens if you try to add a ppa that already exists again. This could lead to problems.
  • You have to execute the script as root
17
New way: you can use Ubuntu Make. To install on 16.04 (Xenial) [and later]
sudo apt install ubuntu-make
If your Ubuntu version if before 16.04 (codename Xenial), you can install from the Ubuntu Make PPA. First, add the PPA to your system:
sudo add-apt-repository ppa:ubuntu-desktop/ubuntu-make
sudo apt-get update
Then, installing Ubuntu Make:
sudo apt-get install ubuntu-make
After installing Ubuntu Make, do a
umake ide idea
serv-inc
  • 3,159
  • 26
  • 32
You can also try my ubuntu repository: https://launchpad.net/~mmk2410/+archive/ubuntu/intellij-idea-community
To use it just run the following commands:
sudo apt-add-repository ppa:mmk2410/intellij-idea-community
sudo apt-get update
sudo apt-get install intellij-idea-community
D Nilesh
  • 171
I kept installing various JB tools on a bunch of machines, so finally wrote a tiny tool to help with that, check it out here: https://github.com/MarcinZukowski/jetbrains-installer
It's also useful when JetBrains releases a new version requiring manual download, allows automating that.
Installing JDK
Oracle JDK
sudo add-apt-repository ppa:webupd8team/java`
sudo apt-get update
OpenJDK
sudo apt-get install openjdk-8-jdk
You can also install openjdk 9, 10 or 11 this is as per your choice; just replace 8 with version number to install another version.
Installing Intellij
Installing intellij from snap store
sudo snap install intellij-idea-ultimate --classic --edge
This is a ulimate edition so you need activation code in order to activate it.
sudo snap install intellij-idea-community --classic
This is community version so don't need activation code; but it has limited features and tools.
Happy Coding :)
rhoitjadhav
  • 824
  • 14
