I installed the Linux header file for my kernel using command:
sudo apt-get install linux-headers-`uname -r`
In the folder
/usr/src/linux-headers-2.6.32-21-generic
all the files have broken links.
Example: The file linux-headers-2.6.32-21/crypto has broken link points to ../linux-headers-2.6.32-21/crypto.
Output of
ls -l /usr/src/linux-headers-2.6.32-21-generic :
drwxr-xr-x 3 root root   4096 2013-03-25 18:39 arch
lrwxrwxrwx 1 root root     32 2013-03-25 18:39 block -> ../linux-headers-2.6.32-    21/block
lrwxrwxrwx 1 root root     33 2013-03-25 18:39 crypto -> ../linux-headers-2.6.32-21/crypto
lrwxrwxrwx 1 root root     40 2013-03-25 18:39 Documentation -> ../linux-headers-2.6.32-21/Documentation
lrwxrwxrwx 1 root root     34 2013-03-25 18:39 drivers -> ../linux-headers-2.6.32-21/drivers
lrwxrwxrwx 1 root root     35 2013-03-25 18:39 firmware -> ../linux-headers-2.6.32-21/firmware
lrwxrwxrwx 1 root root     29 2013-03-25 18:39 fs -> ../linux-headers-2.6.32-21/fs
drwxr-xr-x 5 root root   4096 2013-03-25 18:39 include
lrwxrwxrwx 1 root root     31 2013-03-25 18:39 init -> ../linux-headers-2.6.32-21/init
lrwxrwxrwx 1 root root     30 2013-03-25 18:39 ipc -> ../linux-headers-2.6.32-21/ipc
lrwxrwxrwx 1 root root     33 2013-03-25 18:39 Kbuild -> ../linux-headers-2.6.32-21/Kbuild
drwxr-xr-x 2 root root   4096 2013-03-25 18:39 kernel
lrwxrwxrwx 1 root root     30 2013-03-25 18:39 lib -> ../linux-headers-2.6.32-21/lib
lrwxrwxrwx 1 root root     35 2013-03-25 18:39 Makefile -> ../linux-headers-2.6.32-21/Makefile
lrwxrwxrwx 1 root root     29 2013-03-25 18:39 mm -> ../linux-headers-2.6.32-21/mm
-rw-r--r-- 1 root root 640617 2010-04-16 18:37 Module.symvers
lrwxrwxrwx 1 root root     30 2013-03-25 18:39 net -> ../linux-headers-2.6.32-21/net
lrwxrwxrwx 1 root root     34 2013-03-25 18:39 samples -> ../linux-headers-2.6.32-21/samples
drwxr-xr-x 7 root root   4096 2013-03-25 18:39 scripts
lrwxrwxrwx 1 root root     35 2013-03-25 18:39 security -> ../linux-headers-2.6.32-21/security
lrwxrwxrwx 1 root root     32 2013-03-25 18:39 sound -> ../linux-headers-2.6.32-21/sound
lrwxrwxrwx 1 root root     26 2013-03-25 18:39 source -> /build/buildd/linux-2.6.32
lrwxrwxrwx 1 root root     32 2013-03-25 18:39 tools -> ../linux-headers-2.6.32-21/tools
lrwxrwxrwx 1 root root     33 2013-03-25 18:39 ubuntu -> ../linux-headers-2.6.32-21/ubuntu
lrwxrwxrwx 1 root root     30 2013-03-25 18:39 usr -> ../linux-headers-2.6.32-21/usr
lrwxrwxrwx 1 root root     31 2013-03-25 18:39 virt -> ../linux-headers-2.6.32-21/virt
Output of:
uname -r
2.6.32-21-generic
How should i fix this? (I want the headers files without broken links).
Those missing files in the /usr/src/linux-headers-2.6.32-21 directory are provided by the package linux-headers-2.6.32-21 Install linux-headers-2.6.32-21. To get them, try installing that package.
If you want to install it from the command line, run:
sudo apt-get update && sudo apt-get install linux-headers-2.6.32-21
(The apt-get update part will help to make sure the system installs the package based in correct and consistent information about what packages are available from where and in what versions.)
Eliah Kagan
  • 119,640
