32
I'm using Byobu (with Tmux, inside of gnome-terminal) and I have a problem with its keybindings (which I probably fail to understand).
I launch byobu, open a few windows then, from one of these windows, I ssh into another machine and launch byobu there. No matter if I press Ctrl-c or Ctrl-a-c, I'm not sure how to create and switch between windows in this remote session.
Note: if I enter Shift-F12 I can switch between windows using the Function keys in the remote session but this is less than ideal as I also need to switch between windows in the main session.
Any ideas?
Thanks in advance for your help.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
tseliot
  • 378
I found using Shift-F12 to toggle on/off the outer byobu's keybindings is a bit easier to remember and use. The only new key to remember is Shift-F12, and then the inner byobu can be controlled with the normal F- keybindings.
Found that solution here.
Also useful is that Shift-F12 is listed in the keybindings list of byobu's internal help which is accessible by Shift-F1 or the F1 menu's "Help - Quick Start Guide".
mp3foley
  • 451
26
I'm assuming that you configured byobu to use Ctrl-A as tmux's escape sequence.
The commands that you type in your terminal are first handled by your local tmux instance, then handled by the nested tmux session. This means you need to escape twice to go to the nested instance:
  • Ctrl-a c # opens a window in your local session
  • Ctrl-a Ctrl-a c # opens a window in your remote session
If the second line does not work, try (as pointed out by @artm)
  • Ctrl-a a c # second a without Ctrl
Zanna
  • 72,312
Ctrl-a Ctrl-a also didn't work for me. I found that it worked after commenting the following line in .byobu/keybindings.tmux:
unbind-key -n C-a
Another workaround would be to use the internal Tmux send-key command:
  • select the pane or window where the nested session runs
  • press Ctrl+a : enter send-key -2 and then the command or key you want to send
Examples:
  • Ctrl+a : send-key -2 c = create new window
  • Ctrl+a : send-key -2 p = switch to previous window
  • Ctrl+a : send-key -2 n = switch to next window
Not very intuitive, but works even with Putty.
LiveWireBT
  • 29,597
