I am running Ubuntu 12.04.2 in dual boot with Windows 7 on the same drive.
In Windows, I customize my refresh rate for my 2nd monitor with the program powerstrip. When I export my Linux modeline and create a new mode for Ubuntu, I get the following errors when I try to change my 2nd monitor to that mode:
~$ xrandr --output DFP3 --mode "1400x1050_2"
xrandr: Configure crtc 1 failed
My question is, how can I remedy this problem? I need to have the same custom timings as Wndows.
My specs are:
  • Ubuntu 12.04.2 (3.5.0-23-generic)
  • AMD driver catalyst-13.1-linux-x86.x86_64
  • P6x58D premium motherboard
  • 6 gigs of ram
  • 23 inch Asus monitor
  • 15 inch DIY monitor.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
ryanwc
  • 71
The following steps are needed to change the display mode using xrandr:
1. Get modeline
To change the geometry of an attached screen we first need to calculate the modeline for a desired resolution with gtf or cvt (whatever is installed):
cvt <xres> <yres> <refresh>
For a resolution of 1400x1050 at 50Hz this will give us the follwing modeline:
# 1400x1050 49.97 Hz (CVT 1.47M3) hsync: 54.11 kHz; pclk: 100.00 MHz
Modeline "1400x1050_50.00"  100.00  1400 1480 1624 1848  1050 1053 1057 1083 -hsync +vsync
2. Define new mode
Copy and paste the modeline to add it as a new mode named 1400x1050_50.0 (or any other name we choose) for xrandr:
 xrandr --newmode "1400x1050_50.00"  99.88  1400 1480 1624 1848  1050 1051 1054 1081  -HSync +Vsync
3. Attach mode to monitor
We then attach this new mode to our monitor, e.g. DFP3 (note that this will error if we had chosen a mode not supported by the graphics card driver):
xrandr --addmode DFP3 1400x1050_50.00
4. Change mode
After this was successful we then can switch to this new mode using
xrandr --output DFP3 --mode 1400x1050_50
Takkat
  • 144,580
