Afaik, in gcc, you can set -m32 flag to let it compile linux sources to 32bit executables. I don't have a wide knowledge about Makefiles, but you can tweak them.
edit:
I wanted to add a question from stackoverflow here, in which it is told to set cflags:
export CFLAGS=-m32
And from the linux repository in Torvalds' github account, I found following section on the main makefile that you may find useful, as it tells that you can set a target architecture by setting an environment variable. Read the comments, currently, these lines are from this file, between lines 174-196:
# Cross compiling and selecting different set of gcc/bin-utils
# When performing cross compilation for other architectures ARCH shall be set
# to the target architecture. (See arch/* for the possibilities).
# ARCH can be set during invocation of make:
# make ARCH=ia64
# Another way is to have ARCH set in the environment.
# The default ARCH is the host where make is executed.
# CROSS_COMPILE specify the prefix used for all executables used
# during compilation. Only gcc and related bin-utils executables
# are prefixed with $(CROSS_COMPILE).
# CROSS_COMPILE can be set on the command line
# make CROSS_COMPILE=ia64-linux-
# Alternatively CROSS_COMPILE can be set in the environment.
# A third alternative is to store a setting in .config so that plain
# "make" in the configured kernel build directory always uses that.
# Default value for CROSS_COMPILE is not to prefix executables
# Note: Some architectures assign CROSS_COMPILE in their arch/*/Makefile
export KBUILD_BUILDHOST := $(SUBARCH)
ARCH ?= $(SUBARCH)
CROSS_COMPILE ?= $(CONFIG_CROSS_COMPILE:"%"=%)
# There are more architecture related stuff beyond this line
