21
I want to install MySQL and create a database on it using the following code:
sudo apt-get install mysql-server
mysqladmin -h localhost -u {username} -p create lrs
I get the following message after executing the second line:
    Enter password:
    mysqladmin: connect to server at 'localhost' failed
    error: 'Access denied for user '{username}'@'localhost' (using password: YES)'
What is the problem?
Lucio
  • 19,191
  • 32
  • 112
  • 191
6 Answers6
32
After you've installed MySQL, you need to set mysql root password. To do so:
  1. Enter the next command in a terminal:
    mysql -u root
  2. Now it should open the mysql console. And type the following line:
    SET PASSWORD FOR 'root'@'localhost' = PASSWORD('yourpassword');
To exit from the mysql console enter exit.
Now you should create the database with the root user. To do so:
  1. Open mysql from terminal:
    mysql -u root -p
  2. Enter the password created before.
  3. Enter the following line:
    CREATE DATABASE yourdatabasename;
If you enter SHOW DATABASES; you should see it in the list. If so, you have a database ready to use!
Lucio
  • 19,191
  • 32
  • 112
  • 191
You need to connect to MySQL using the root user and associated password. If you need to set them, use the following command: sudo mysqladmin -u root -h localhost password 'mypassword'
From there, you can configure additional accounts by following this document: How to Create a New User and Grant Permissions in MySQL
guntbert
  • 13,475
Bert
  • 3,455
This is strange because since 12.04 (guessing you're running Kubuntu 12.04), MySQL has been default. Looks like you're missing a few steps in between, so let's look over this:
First, as you mentioned, let's do an installation,
After you installed it, let's try a little test,
sudo netstat -tap | grep mysql
When you run this, you should see this reply,
tcp        0      0 localhost:mysql         *:*                LISTEN      2556/mysqld
If this is not running correctly, run this restart command,
sudo service mysql restart
Now to configure the server.
Let's go to /etc/mysql/my.cnf to configure the basic settings. This includes the Log File, Port Number, Etc. For example, to configure MySQL to listen for connections from network hosts, change the bind-address directive to the server's IP address:
bind-address            = 192.168.0.5
After this, restart the MySQL daemon,
If you want to change the MySQL root password, run this:
sudo dpkg-reconfigure mysql-server-5.5
The daemon will be stopped and you'll be prompted for a new password.
Once you're done, you should be configured and a few google searches will teach you how to create a database
Source: The Ubuntu Server Guide
guntbert
  • 13,475
Run this command:
(5.5 is the version number, adapt if you have a different version)
This will allow you to set your MySQL root password, that you can then use with mysqladmin and mysql commands.
Nicolas Raoul
  • 11,921
-1
mysql -u root -p
Enter Password: (Enter your password here).
-1
I know this is 3 years old but I just had this problem as well and wanted to post my answer in case anyone else does the same search I did.
This indicates that your user doesn't have permission to connect to the database itself, before it even gets to logging in; not the database user, your actual linux user. Run everything as super user: sudo mysql -u root -p
Only root (the linux user, or a user with sudo privileges) can log in to mysql as root (the database user). I wasn't able to find anywhere documenting this but experimentation proved it was the case. You can create a new user with all the same rights as the root user and that will not be restricted.
sudo mysql -u root
CREATE USER 'newuser'@'localhost' IDENTIFIED BY 'password';
GRANT ALL PRIVILEGES ON * . * TO 'newuser'@'localhost';
FLUSH PRIVILEGES;
Now "newuser" (or whatever name you choose) can be logged-in-as without the need for sudo and you can use it for all your database administrative needs.
