I had installed apache,php just now and for checking whether php executes i had opened /var/ww and edited index.html file , but i was unable to save the file. It says i do have the proper permissions to save the file. I had logged in as administrator. I had right clicked the index.html and i was unable to edit permissions it says i am not the owner.
What to do with this?
Thanks to all!
Web-E
  • 21,716
Did you try on your console to edit the file with sudo?
sudo gedit index.html
That should work.
Eliah Kagan
  • 119,640
Using the Terminal go to the specified directory and try running the following command to edit the file:
gksudo gedit index.html
The gksudo command will give you root permission so you will probably be able to edit the file.
Note that I used gedit in the command, because gedit is the default text editor in Ubuntu, but if you are using a Ubuntu variant this text editor is not installed by default. If you're using a variant use nano (command line text editor) instead of gedit, to save the changes press Ctrl + O and then Ctrl + X to exit the text editor.
Zignd
  • 10,982
