root@ubuntu:/etc/openvpn# ls -l test.conf -rw-r--r-- l root root 791 Mar 20 09:23 test.conf
What does the above command mean?
That is not a command. It contains a command.
It's a prompt, followed by a command, followed by the output of the command. The command itself is:
ls -l test.conf
That command displays information about the file called test.conf located in the current directory. The ls command displays (or lists) information about files. The -l flag makes it display the information in long form, rather than just showing the filename.
(ls without a flag like -l is most often used to list multiple files or determine if a file exists, but may be used with a file known to exist; by default in Ubuntu, issuing ls filename will highlight filename in a way that shows what kind of file it is, for example, it will use a certain color if it is a directory, another if it is marked executable.)
The output is:
That means the file:
-rw-r--r-- doesn't start with d)s in -rw-r--r--) and non-sticky (no t)rw- for owner) but only readable by other users (r-- for group members, r-- again for others) — see the community documentation on permissionsroot (with root as its group identity also)test.confThe beginning of the line is a prompt; this is what is displayed to the user in a shell to notify the user they may enter a command. Prompts are often configured to provide helpful information to the user. Here the prompt is:
This means the current user is root, the machine's hostname is ubuntu (which usually means this is a live CD/DVD/USB system, but someone could name their machine ubuntu in an installed system too), and the current directory is /etc/openvpn (which is where configuration data for OpenVPN are stored, see also the Ubuntu OpenVPN documentation).
The # character indicates that this is a superuser shell (which is to be expected as it is owned by root, the superuser); otherwise it would have been $ (but please note that this convention is not universally followed, and some shells default to % which does not indicate anything about the shell's capabilities).
I think that you have a misunderstanding with the structure of that line.
The first sentence is telling the user at a determined computer that is in the mentioned folder:
Here you have:
and the corresponding separators between them are @, : and #
The command, that is after the last separator (#), is:
ls -l test.conf
The output that you get is:
