I dropped my laptop (from a chair!) and now it does not boot. It shows me only the grub menu screen. Using the recovery mode it gave me:
No init found.Try passing init=bootarg  and prompted (initramsfs)
Then, I used a live cd and did:
sudo fdisk -l
 Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048      292863      145408   83  Linux
/dev/sda2          294910    95995903    47850497    5  Extended
/dev/sda3        95995904   312580095   108292096   83  Linux
/dev/sda5        88184832    95995903     3905536   82  Linux swap / Solaris
/dev/sda6          294912    23730175    11717632   83  Linux
/dev/sda7        23732224    88178687    32223232   83  Linux
I did : sudo fsck /dev/ for all the devices.
All were fine except from /dev/sda2 which gives :
fsck.ext2: Attempt to read block from filesystem resulted in short
read while trying to open /dev/sda2
/dev/sda5 :
fsck: fsck.swap: not found fsck: error 2 while executing fsck.swap for
/dev/sda5
and /dev/sda6 :
/dev/sda6 contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Error reading block 659 (Attempt to read block from filesystem resulted in short read).  Ignore error<y>? no
Error while iterating over blocks in inode 7: Attempt to read block from filesystem resulted in short read
e2fsck: aborted
(I don't know what to answer at "Ignore error")
After that, I rebooted and chose recovery from the menu grub. Now, it gave me no longer the "No init found" , it showed me a ncurses menu where I did system check and grub (these options).
The system check gave me:
/dev/sda6: UNEXPECTED INCONSISTENCY RUN fsck MANUALLY Error reading
block 659  /dev/sda6 contains a file system with errors mountall:The
system file contains errors mountall:Ignoring Plymouth not available
(sth like that) fsck [866] terminating with condition 4
What can I do?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
George
  • 411
My guess is that the hard drive has broken down due to the fall. I'd try to backup your files as fast as you can, using the live CD.
To check the device for errors, you can run sudo fsck -t ext3 /dev/sdaX again.
I think you'll have to get a new hard drive and reinstall your PC though.
