yEd uses Java's metallic theme by default. What you want is Java's GTKLookandFeel theme. Normally you would be able to do this by starting yEd with:
java -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel -jar yed.jar
Due to a bug in yEd/Java this does not work currently. For now you will have to apply the
following workaround:
1.) Navigate to yEd's installation folder
cd $HOME/.yed
2.) Edit yed.jar and delete the class causing the theme issues
mv yed.jar yed.zip
zip -d yed com/jgoodies/looks/plastic/Plastic3DLookAndFeel.class
mv yed.zip yed.jar
You can now start yEd in GTK mode.
With some Java versions you might run into a scenario where all fonts in the GTK theme are formatted in bold. You can troubleshoot this by uninstalling a korean font package:
sudo apt-get remove --purge fonts-unfonts-core
If you don't feel like removing packages just to troubleshoot Oracle's bugs you can try out the workaround outlined in this comment.
References:
http://forum.ubuntuusers.de/topic/java-programm-yed-aussehen-anpassen/#post-5244382
https://bugs.launchpad.net/ubuntu/+source/openjdk-7/+bug/937200
