running Ubuntu 12.04, I had the usual python 2.7 in place .
I needed python 2.6 , so I downloaded the source and did
./configure
make
sudo make install
A mistake, as I did not want to replace my system-wide python . Now some programs stopped working , e.g. update-manager with
ImportError: No module named gi.repository
I used update-alternatives to make python 2.7 default again, but many python applications still won't start up because of some missing modules .
Can someone give a hint what happened and what the best way to fix it would be?
Thanks in advance.
Edit :
I could get some functionality of apt-get to work by setting my own hard link from /etc/python to /etc/python2.7 . ( So I guess using update-alternatives really did not do much good eithe. ) I did a dist-upgrade , which basically worked, but a lot of the package managing via apt-get is still broken. In particular, a problem with python-minimal prevents many other installations of packages I wanted to do .
Setting up python-minimal (2.7.3-0ubuntu7) ...
Traceback (most recent call last):
  File "/usr/local/lib/python2.7/runpy.py", line 162, in _run_module_as_main
    "__main__", fname, loader, pkg_name)
  File "/usr/local/lib/python2.7/runpy.py", line 72, in _run_code
    exec code in run_globals
  File "/usr/local/lib/python2.7/compileall.py", line 16, in <module>
    import struct
  File "/usr/local/lib/python2.7/struct.py", line 1, in <module>
    from _struct import *
ImportError: No module named _struct
dpkg: error processing python-minimal (--configure):
 subprocess installed post-installation script returned error exit status 255
PS: Building 2.7 from source always did exit (also before dist-ugprade or update-alternatives) with
make: *** [libinstall] Error 1
Currently, on make , there are more issues (" Python build finished, but the necessary bits to build these modules were not found: _bsddb bsddb185 bz2
dl imageop sunaudiodev
To find the necessary bits, look in setup.py in detect_modules() for the module's name. ")
As this is a little over my head , I guess I am just better off with a fresh install from scratch .
Braiam
  • 69,112
mfit
  • 151
I had a similar problem when I downgraded from debian/Testing to debian/Stable recently. I guess somewhere in the process, python modules got corrupted. Purging and reinstalling python was, as it was pointed out, a bit draconian. Thankfully, I came across the following http://ubuntuforums.org/showthread.php?t=735693
Following this suggestion, I tried the command
for pkg in `dpkg --get-selections | egrep -v 'deinstall' | egrep python | awk '{print $1}'`; do  apt-get -y --force-yes install --reinstall $pkg ; done
to reinstall anything that has python in its name, and that solved the problem.
Soroosh
  • 151
Your python 2.6 install has probably changed lots of settings and paths.
Your best bet is to reinstall the default python interpreter
sudo apt-get --reinstall install python python-support
I can't test it, but I hope that it works. Good luck.
If it doesn't work the only other idea that I have is to install python 2.7 from source, and afterwards trying to reinstall the default one again.
Javier Rivera
  • 35,434
I ran into essentially the same issue, but for python-minimal 2.7.11-1.
cat /var/lib/dpkg/info/python-minimal.postinst
You should get something like this:
#! /bin/sh
set -e
python2.7 -m compileall /usr/share/python/ >/dev/null
Run the command without redirect to >/dev/null (edit the file, or: sudo python2.7 -m compileall /usr/share/python/). This will show you where post installation configuration is failing.
Ex:
Listing /usr/share/python/penemue/lib/python2.7/site-packages/gevent
Compiling /usr/share/python/penemue/lib/python2.7/site-packages/gevent/_socket3.py ...
  File "/usr/share/python/penemue/lib/python2.7/site-packages/gevent/_socket3.py", line 183
    def makefile(self, mode="r", buffering=None, *,
SyntaxError: invalid syntax
In my case, it was a custom python package (built using dh-virtualenv) that lived under /usr/share/python. I had to run dpkg -P penemue and ultimately remove the /usr/share/python/penemue directory. I might have been able to just move the /usr/share/python/penemue directory out of the way.
Once I got rid of the bad code, running sudo apt-get install -f resolved the issues.
ytjohn
  • 391
My guess is that you accidentally got overwrote the default python directory (somehow) and 2.6 is incompatible with what update manager/apps need.
Try sudo apt-get purge python2 then sudo apt-get install python2. This should purge python from your system and reinstall it, making it the default Python again.
Only other idea is that you got a bad source for 2.6 and it as such made a bad install that wasn't bad enough to be detected by make???
