I was tried to install the "prozilla" but ,i was cancel the installing while process is run.so now here,below error is occurred ,when i try to install any software.that's mean i can't install any software ,because this.Does anyone know what mean this error and how can i solve this case.thanks
You might want to run 'apt-get -f install' to correct these:
 apt-proz : Depends: prozilla but it is not going to be installed
 aptitude : Depends: aptitude-common (= 0.6.8.1-2ubuntu1) but it is not going to be installed
            Depends: libboost-iostreams1.49.0 (>= 1.49.0-1) but it is not going to be installed
            Depends: libcwidget3 but it is not going to be installed
            Depends: libept1.4.12 (>= 1.0.9) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
sudo apt-get -f install
Have you tried running this command in terminal? This should help.
Ivan
  • 116
