I have Ubuntu 12.10 running as a VMware guest on my Windows 8 host.
I have shared a folder on my Windows 8 Host and it is mounted in the Ubuntu guest on startup using this entry in fstab:
//myhost/work /work cifs credentials=/home/user/.smbcredentials,noserverino,nounix,uid=user,gid=user,file_mode=0777,dir_mode=0777 0 0
The share works fine and is able to be served by a webserver such as nginx.
However, there seems to be issues when I install node.js packages using npm, I get a bunch of errors like this:
user@ubuntu:/work/test$ sudo npm install grunt
npm http GET https://registry.npmjs.org/grunt
npm http 304 https://registry.npmjs.org/grunt
npm ERR! error rolling back Error: ENOTEMPTY, rmdir '/work/test/node_modules/grunt/node_modules/lodash'
npm ERR! error rolling back grunt@0.4.1 { [Error: ENOTEMPTY, rmdir '/work/test/node_modules/grunt/node_modules/lodash']
npm ERR! error rolling back errno: 53,
npm ERR! error rolling back code: 'ENOTEMPTY',
npm ERR! error rolling back path: '/work/test/node_modules/grunt/node_modules/lodash' }
npm ERR! Error: UNKNOWN, symlink '../which/bin/which'
npm ERR! If you need help, you may report this log at:
npm ERR! <http://github.com/isaacs/npm/issues>
npm ERR! or email it to:
npm ERR! <npm-@googlegroups.com>
npm ERR! System Linux 3.5.0-26-generic
npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "grunt"
npm ERR! cwd /work/test
npm ERR! node -v v0.10.0
npm ERR! npm -v 1.2.14
npm ERR! path ../which/bin/which
npm ERR! code UNKNOWN
npm ERR! errno -1
npm ERR! Error: ENOENT, chmod '/work/test/node_modules/grunt/node_modules/findup-sync/test/fixtures/aaa.txt'
npm ERR! path /work/test/node_modules/grunt/node_modules/findup-sync/test/fixtures/aaa.txt
npm ERR! fstream_path /work/test/node_modules/grunt/node_modules/findup-sync/test/fixtures/aaa.txt
npm ERR! fstream_type File
npm ERR! fstream_class FileWriter
npm ERR! fstream_finish_call chmod
npm ERR! code ENOENT
npm ERR! errno 34
npm ERR! fstream_stack /usr/lib/node_modules/npm/node_modules/fstream/lib/writer.js:305:19
npm ERR! fstream_stack Object.oncomplete (fs.js:93:15)
npm ERR! Error: ENOENT, lstat '/work/test/node_modules/grunt/node_modules/minimatch/test/basic.js'
npm ERR! path /work/test/node_modules/grunt/node_modules/minimatch/test/basic.js
npm ERR! fstream_path /work/test/node_modules/grunt/node_modules/minimatch/test/basic.js
npm ERR! errno 34
npm ERR! fstream_stack /usr/lib/node_modules/npm/node_modules/fstream/lib/writer.js:284:26
npm ERR! Error: ENOENT, lstat '/work/test/node_modules/grunt/node_modules/glob/test/00-setup.js'
npm ERR! not ok code 0
What could be causing this problem? From the command line, I can chmod, rmdir among other things using sudo without any issues.
