I'm trying to install Ubuntu along with my existing Windows 8 OS (the computer came with Windows 7 so I'm supposed to have the old BIOS).
The problem is that when I tried installing Ubuntu from a USB drive I didn't have the option to install it alongside Windows, I've been told that the problem is that I've got 4 partitions and more partitions just can't be added. Partitions
These are the partitions I have on my machine, I think I'll try resizing the Windows7_OS partition in order to free some space and delete one of the others partitions. The question is which one can be removed safely.
Other solutions for running Ubuntu will be appreciated as well :)
B.T.W
I'm using a U310 which is supposed to have 32GB SSD storage as well as 500GB HDD Storage
eladrich
  • 337
There may be two issues here.
First, as you have found out you need to delete 1 of 4 primary partitions to create more (extended) partitions. I second @Mordoc's comment above. Backup and remove D:. Do not format, keep in unallocated so that Ubuntu installation process can find it and create its own sets of partitions / and swap.
If you want more space for Ubuntu, you can shrink C: and make the unallocated space a bit bigger.
Second, The 32GB SSD is used by Windows in such a way that is not compatible with Ubuntu installation. This has been discussed before in another question. See Can't see HDD during install 12.04 on Lenovo U310 for a solution to that problem.
See Is a 40GB SSD practical to use for ' / ' for some ways of using the SSD and HDD for Ubuntu.
Hope this helps
user68186
  • 37,461
