currently I use this to count the number of available updates
NUMOFUPDATES=$(aptitude search "~U" | wc -l)
Is there a way to do the same with apt(not aptitude) but not using the update-notifier?
I suppose the fastest method is shown in apticron:
https://salsa.debian.org/debian/apticron/blob/master/apticron#L121-154
This can be distilled to:
apt-get -q -y --ignore-hold --allow-change-held-packages --allow-unauthenticated -s dist-upgrade | /bin/grep ^Inst | wc -l
You can use apt-get -s to simulate an upgrade process and extract only the number of upgraded packages by
LANG=C apt-get upgrade -s |grep -P '^\d+ upgraded'|cut -d" " -f1
This will result in just the number of packages
I just run the command:
sudo apt-get update && sudo apt-get upgrade
After performing the update process, it gives the output for upgrade command as:
Reading package lists... Done
Building dependency tree
The following packages will be upgraded:
wine1.5 wine1.5-i386
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 24.1 MB of archives.
After this operation, 286 kB of additional disk space will be used.
Do you want to continue [Y/n]?
The 6th line mentions that there are 2 upgrades available and the 5th line lists the packages for which the upgrades are available. If I not in the mood to install the upgrades right at that moment I press n and move on.
Straight and simple.
Note: If there are kernal updates available as well, it would show them as <x> not upgraded.
