bluefish 2.2.12
(on KDE/Plasma)
as OP wrote: no menu entry (it's in the settings dialog)
pressing shortcuts when menu ishighlighted does nothing,
and BACKSPACE does nothing.
however, modifying ~/.bluefish/menudump does work, under these conditions:
- must restart bluefish after changes
- remove the
; in front of edited line. otherwise ; means line is commented out, and has no effect. (it's an archaeological remnant)
- there's no collision test: before entering a shortcut, make sure it's not assigned elsewhere in the file.
Cool and sexy it is not.
Also note:
ctrl key here is:
I assume the "backspace-highligh" trick (which is also archaeological remnant) works in certain Gnome environmnet, but not in others. It's extremely error prone, bad UI/UX, shitty way to assign shortcuts, though, and I wouldn't do it even if it was working in my environment.
