The hidden menu option isn't working. I want the menu to remain hidden during boot but show up when I press a button.
I have /etc/default/grub configured as follows:
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=10
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
With the settings:
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
The menu doesn't appear if I press nothing, and I can tell the computer is waiting 10 seconds to boot. The problem is no matter what I press (Esc, Tab, Shift, Enter) and no matter when I press it or if/when I hold it, I can't get the menu to come up. The only thing that appears is the text: Grub Loading...
Any suggestions would be greatly appreciated!
karel
  • 122,292
  • 133
  • 301
  • 332
Eric
  • 71
This solution by Bolodya @ bugs.launchapd.net worked for me:
I had the same problem - cant access to grub menu by esc or shift keys during boot if I tried to hide it (I have windows and ubuntu on one disk).
The reason is one strange condition in /etc/grub.d/30_os-prober script. it bloks hidden menu part of grub.cfg if os-probber found any other os.
So for me works the following:
  1. In the file /etc/grub.d/30_os-prober
    • comment line 33: if [ "x${found_other_os}" = "x" ] ; then
    • and comment closing it "fi" at line 67
  2. Sudo update-grub
After that if you have GRUB_HIDDEN_TIMEOUT >=1 then you can access to grub menu by esc key during this timeout, if you have GRUB_HIDDEN_TIMEOUT =0 then you can access to grub menu if you press "shift" during grub startup, and no hidden menu if GRUB_HIDDEN_TIMEOUT =-1.
For me the lines were 32 and 66 respectively
copycat
  • 51
The line that says
GRUB_HIDDEN_TIMEOUT_QUIET=true is right.
I think you also need to change GRUB_TIMEOUT=0 instead of 5 and GRUB_HIDDEN_TIMEOUT=10 to make the menu not show up unless the Shift key is held during boot.
You may want to set a time smaller than 10 seconds (3-5 works for me) or you'll be waiting a while before GRUB boots the kernel.
Let me know if this is still not working for you!
reference
Mark Paskal
  • 2,890
