Cody again. I'm still sort of a noob at installing things so I need your help... Im trying to install hping3 and of course it's a .tar.gz file... I've looked everywhere even on here and no solutions... Please help!!
Asked
Active
Viewed 1.7k times
the above answer is an easy and efficient solution but if you want to install through tar.gz first you need to extract is using
tar -xvvf [filename.tar.gz]
then you need to configure the source code contained in tar.gz with command
./configure
after that do
make
make install
to install your program and you are done.
PS: you need to be present in the specific folder extracted. that's all.
igauravsehrawat
- 407
AFAIK, it should be already available in Ubuntu repositories (12.10), so simply do this:
sudo apt-get install hping3
In case that it's really tar.gz, then you can extract it by using: tar -xvzf hping3.tar.gz
Then, you have to compile the source code, typically by using "make" command (you'll need installing the build tools):
sudo apt-get install build-essential
Take this as a hint ;-).
