Depending on his type of usage, an Ubuntu user may spend a lot of time in front of a terminal. Knowing some keyboard shortcuts can make you save a lot of time (ex: copy/paste text, move between the prompt text, etc).
So which bash tips/shortcuts do you guys know?
Salem
  • 19,864
  • 65
  • 90
Output management
  • Shift+PageUp/Shift+PageDown - Scrolling the terminal output. This is very handy when using an tty: in Gnome Terminal works the same way as dragging the scroolbar.
  • Ctrl+s - Pauses the output: the command keeps running, only their output stops.
  • Ctrl+q - Resume the output: when output is paused, this will make the command show their output again.
  • Ctrl+l - Clear terminal output.
Prompt text manipulation
  • Ctrl+u - Deletes all the text currently typed in the prompt.
  • Ctrl+k - Deletes all the text from the right of the cursor
  • Ctrl+w - Deletes a word, from right to left.
  • Ctrl+a - Move to the beginning of the text.
  • Ctrl+e - Move to the end of the typed text.
  • Ctrl+Left/Right arrow - Move to the beginning/end of the previous/next word.
Command execution
  • Tab - Lists available commands from the typed text.
  • Up/Down arows - Shows previous/next command executed.
  • Ctrl+r - Searches the last command executed from the given text.
  • Ctrl+c - Stops the current command.
  • Ctrl+z - Sends the program to the background. Can then be managed using fg/jobs.
  • Ctrl+d - Logs out from the current terminal. Similar to typing exit.
Salem
  • 19,864
  • 65
  • 90
There are many more, but ones I use a lot:
  • Repeat/insert the previous command: !!
    $ which rename
    /usr/bin/rename
    $ file $(!!)
    file $(which rename)
    /usr/bin/rename: symbolic link to `/etc/alternatives/rename'
  • Select words from the previous command: !:1, !:2, etc.
    $ ls /var/lib/logrotate/*
    /var/lib/logrotate/status
    $ cat !:1
    cat /var/lib/logrotate/*
    ... contents ...
  • Fix typo in previous command: ^x^y and ^x
    $ lls
    lls: command not found
    $ ^l
    ls
    ... listing ...
    $ ^s^l
    ll
    ... long listing ...
zwets
  • 12,770
  • 37
  • 46
