I am installing Grails on 12.10, using the instructions on grails.org, but am getting an error on the 3rd step, as outlined below.
sudo add-apt-repository ppa:groovy-dev/grails
sudo apt-get update
sudo apt-get install grails-ppa
The error I get is shown below. I have the Sun JDK installed, and JAVA_HOME is set, and JAVA_HOME/bin is on the path.
Can someone suggest things to try to resolve this?
Reading package lists... Done
Building dependency tree
default-jre-headless:i386 : Depends: openjdk-7-jre-headless:i386 (>= 7~u3-2.1) but it is not going to be installed
openjdk-7-jre:i386 : Depends: openjdk-7-jre-headless:i386 (= 7u7-2.3.2a-1ubuntu1) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
java -version
java version "1.6.0_39"
Java(TM) SE Runtime Environment (build 1.6.0_39-b04)
Java HotSpot(TM) 64-Bit Server VM (build 20.14-b01, mixed mode)
