I've just got my first 64-bit-capable laptop (previously I've only dealt with 64-bit on servers). Of course the first thing I am going to do is to format the hard drive and install Ubuntu instead of Vista, and the question is should I install 32-bit or 64-bit Ubuntu?
Here are the details which can matter:
CPU: Core 2 Duo 2 GHz, RAM: 3.45 GB. I am going to intensively use multitasking, virtualization (VirtualBox) and run memory-heavy Java, C# and native applications.
I ask because my experience shows that 32-bit desktop systems usually work faster and consume less memory. And as far as I know (have read somewhere, never tried myself) 64-bit Java is known to be extremely RAM-wasting compared to 32-bit JRE.
Ivan
  • 58,745
6 Answers6
Points to consider:
  • Because address space is larger, applications do consume more RAM. It's ralatively tiny but can be a deciding factor if RAM is the deciding factor (eg in a rented server). Desktop and even laptop RAM is cheap though.
  • Native programmes do run faster but it's not always a tangible difference. For big things however (as you suggest you'll be doing) it can make a real difference.
  • Compatibility is larely irrelevant these days. Flash is available and Sun Java works (there's even a native JRE that's fairly complete). You can run most pure 32bit binaries just fine, it's just a case of installing its dependencies.
  • Security is not really a factor. 32bit kernels support NX bits and most of the touted features.
  • Neither is the total memory limit unless you have processes that require more than 4GB of RAM. The PAE kernel works.
  • You shoud also look to the future. I don't like to reinstall when I can help it. The future is 64 bit and its performance gains will only increase s GCC gets further extended register optimisations.
In balance, unless this was a very RAM-tight system with no scope for upgrade, I'd go 64 bit.
Oli
  • 299,380
I highly recommend 64 bit operating systems wherever possible. One of the biggest benefits is security, though you also get an increase in speed, the maximum supported memory, and a few other areas. For running Virtual systems, 64 bit systems tend to be a better fit :)!
RolandiXor
  • 51,797
You should take in consideration that there may be some software which runs into 32 bit versions of Ubuntu and there is NO such version for 64 bit version. So, even when you have those so-called "alternatives" to perform almost any task in 64 bit versions, make sure that you have found an "alternative" that fits your needs and makes you feel comfortable.
In example: To the date, I haven't found an alternative for a 64 bit version that makes me feel as happy as Mobile Media Converter does.
Many people can say that I "can do some things about" but what I wish is Mobile Media Converter for a 64 bit version.
Nowadays they have released a 64 bit version right here.
Further than that and even when you can force the software to install, you may experience problems to perform everything you are used to do with ease in a 32 bit system.
Good luck!
BTW: There is no need to add comments related to "alternatives" to Mobile Media Converter. The rest of the comments are welcome.
Definately, yes.
Using Virtualbox myself for a 500ish user network with several virtual machines, and no problems at all here. And since this works perfectly, only going with 32-bits would be a waste.
If your system has 4GB of ram or more, then yes. Thats the quick and obvious answer (and I noticed nobody else mentioned it)
djangofan
  • 3,874
No question here, the answer is Yes. If you have more than 3.8 GB or so of RAM, you won't use it with 32-bit.
I use 64-bit for desktop Ubuntu (and other distros) as well as server ubuntu (and other distros). I have not personally run into any issues or reasons not to use 64-bit, and I've had more than 4GB of RAM on every system for about 4 years; therefore, I never felt 32-bit was an option for me (and although many would say "your milage may vary" here, I think 64-bit is old enough now to be considered tried, tested, and true).
static
  • 131
