I can't work out how to do it. When I try to use my Windows installation disk, it won't even show a setup menu.
I installed Ubuntu via a USB stick, and it is the only OS on my hard drive.
BuZZ-dEE
  • 14,533
There is nothing to do with ubuntu. In time of installation you can format your disk from windows setup.
If you are using Windows disk,
  • Open up BIOS.
  • Change boot-priority to boot from optical disk first.
If you are using USB installation of Windows
  • Open up BIOS with device plugged in.
  • Change boot-priority to boot from USB.
Your USB may be detected as HDD,only in such case in boot-priority select HDD as first one. Then in HDD order change the order to list the USB before your hard disk. You should be able to boot.
If you are sure, you are booting from correct media, still windows setup doesn't start then the disk is corrupt or not bootable.
Web-E
  • 21,716
Use the Ubuntu USB to format the Drive to NTFS and then put the Windows CD or whatever you use
