I reported a bug, which was marked as a duplicate of another bug, and then a duplicate of another bug -- which is fine, I think it is a duplicate.
First off, the architecture is different. The original bug, #1023645, is Architecture: amd64 while the bug I reported is Architecture: i386 and so it I feel I should question as to whether it should be separate.
In any event, what should I do in order to use ndiswrapper? It looks to me that ndiswrapper is installed:
thufir@dur:~$
thufir@dur:~$ aptitude search ndiswrapper
i ndiswrapper-common - Common scripts required to use the utilities
i ndiswrapper-dkms - Source for the ndiswrapper Linux kernel modul
v ndiswrapper-modules-1.9 -
i ndiswrapper-source - Source for the ndiswrapper Linux kernel modul
i ndiswrapper-utils-1.9 - Userspace utilities for the ndiswrapper Linux
thufir@dur:~$
I'm only using xfce, but seem able to bring up ndisgtk as so:
thufir@dur:~$
thufir@dur:~$ sudo ndisgtk
(ndisgtk:4797): libglade-WARNING **: Could not load support for `gnome': libgnome.so: cannot open shared object file: No such file or directory
/usr/sbin/ndisgtk:127: GtkWarning: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file '/root/.local/share/recently-used.xbel.ZZ68TW': No such file or directory
gtk.main()
/usr/sbin/ndisgtk:127: GtkWarning: Attempting to set the permissions of `/root/.local/share/recently-used.xbel', but failed: No such file or directory
gtk.main()
thufir@dur:~$
Does the fact that ndisgtk runs indicate that everything is ok?
