I am running Ubuntu 12.04 on an LTSP network.
I have attached a printer to the server via USB.
The printer is an HP LaserJet Pro P1102 with driver Foomatic/foo2zjs-z2 (recommended).
Often the printer goes to sleep, and then jobs submitted do not get printed. Even when the printer is turned on to force waking.
How can I wake up the printer so the print jobs will be executed?
I had the same problem with HP P1102 and CUPS server and here is what I did. Open your server terminal (I assume CUPS has been already installed and P1102 hooked up in one of your server USB ports). In terminal enter:
lsusb
You should see the following for your HP P1102:
Bus 001 Device 003: ID XXXX:XXXX HP, Inc LaserJet P1102
The first XXXX is your Vendor ID and second XXXX is your Product ID.
Then create a file:
sudo nano /etc/udev/rules.d/51-printer.rules
And insert the following (change XXXXs relevant to your values from lsusb output):
SUBSYSTEM=="usb", ATTRS{idVendor}=="XXXX", ATTRS{idProduct}=="XXXX", MODE:="774", GROUP="lp"
Safe the file and reload udev rules:
sudo udevadm control —reload-rules
Now CUPS will be able to wake up your printer next time you start using it.
Type
cupsenable printername
in konsole
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
XTR
