41
Where are extensions stored once they've been installed to Chromium?
John
  • 1,367
7 Answers7
40
Extensions are (usually) stored at ~/.config/chromium/Default/Extensions. Here's an example featuring the amazing adblock:
jake@daedalus:~$ cd .config/chromium/Default/Extensions/
jake@daedalus:~/.config/chromium/Default/Extensions$ ls
gighmmpiobklfepjocnamgkkbiglidom/  jggheggpdocamneaacmfoipeehedigia/
jake@daedalus:~/.config/chromium/Default/Extensions$ cd gighmmpiobklfepjocnamgkkbiglidom/2.3.1_0/
jake@daedalus:~/.config/chromium/Default/Extensions/gighmmpiobklfepjocnamgkkbiglidom/2.3.1_0$ ls
adblock.js        background.html  blacklisting/         button/     functions.js  img/        jquery/    manifest.json  pages/   whitelister.js
adblock_start.js  blacklister.js   broadcast_channel.js  filtering/  Icon.png      Info.plist  _locales/  options/       port.js
To see it in your file browser, make sure you can see hidden files (View > Show Hidden Files). Or, do like Gaurav says and type in the path after pressing ctl+l.
djeikyb
  • 32,005
11
While the usual profile path for Chromium-based browser is in ~/.config/chromium/<name of profile>
This is wrong if you under these circumstances:
  • have multiple users in Chromium
  • specified the user profile path in Chromium
  • config folder is different if you're using app containers (snap/Flatpak/AppImage).
Visit chrome://version/ in your Chrome and check "Profile Path" for the definitive answer.
leesei
  • 211
Type this in Nautilus after pressing "ctrl+L"
They are located in:
/home/USER_NAME/.config/chromium/Default/Extensions/
Where USER_NAME is your user name.
Lincity
  • 25,749
If you are using Google chrome then look in ~/.config/google-chrome/Default/Extensions
Parto
  • 15,647
It also can be in
/snap/chromium/common/chromium/Default/Local Extension Settings
verify where is installed path.
chrome://version/
Vitalicus
  • 189
On the filesystem? In ~/.config/chromium/Default/Extensions (a hidden folder inside your home directory).
8128
  • 28,868
LGB
  • 1,567
