I'm running Ubuntu 12.10 64bit and having issues using primus (due to nvidia optimus) to run World of Warcraft in Crossover..
I'm getting the following:
steorra@perpetual:~$ primusrun /opt/cxoffice/bin/wine --bottle "World of Warcraft" --cx-app "Wow.exe"
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or directory
Xlib:  extension "NV-GLX" missing on display ":0".
Direct3D9 is not available without OpenGL.
I've tried installing the Runtime Libraries for Direct3d9 under the relevant crossover bottle to no avail. Help?
steorra
  • 49
First of all, it's possible that your drivers aren't completely installed. Try running this if you use Nvidia cards ( 32bit, as wine uses 32bit libraries ):
sudo apt-get install nvidia-glx
And this one if you use AMD/ATI cards:
sudo apt-get install fglrx-glx
You might want to re-install / update your drivers, too. You can follow one of these guides:
Nvidia driver doesn't work in 12.10
Nvidia drivers on Ubuntu 12.10
Also try running: LD_LIBRARY_PATH=/usr/lib32/nvidia-current ~/.wine/path/to/your/game
If none of these does work, try running game with -dx9single.
Hope it helps.
Mahdi
  • 576
sudo apt-get install primus-libs-ia32:i386
David Foerster
  • 36,890
  • 56
  • 97
  • 151
719016
  • 6,467
-2
after install nvidia or ati driver edit .../World of Warcraft/WTF/Config.wtf and change
SET gxApi "D3D9"
to
SET gxApi "OpenGL"
David Foerster
  • 36,890
  • 56
  • 97
  • 151
madtux
