Recently I installed Ubuntu 12.04 (first time on Ubuntu).
I have my normal "administrator", and another Guest account.
I was experimenting today with the user accounts, and set my "administrator" account to "standard" in user account settings.
Now whenever something asks me for authentication, it gives me failed message.
I am using the same old password, didn't create new accounts, just changed privileges. I'm sure that the password is correct, because I can still log in.
I tried logging in to root from Terminal, but it gave me that I'm not one of the sudoers.
don.joey
  • 29,392
Rabee
  • 43
The sudoers file works normally via group membership of a user.
As default, you have the following configuration in ubuntu:
 # Members of the sudo group may gain root privileges
 %sudo ALL=(ALL) ALL
As I understand your description, you have dropped the group membership for the sudo group.
Hopefully you have left over another account which is member in the sudo group. If this is true, you can use the following command to fix your user:
 sudo usermod -a -G sudo  USERNAME
If you have given your root user an explicit password (non standard in ubuntu), you can also invoke:
 su -c usermod -a -G sudo  USERNAME
If both isn't possible, you may do the following:
  1. boot your computer with a live/rescue cd (see also https://wiki.ubuntu.com/RecoveryMode)
  2. mount your root partition (aka /) to e.g. /mnt
  3. chroot /mnt usermod -a -G sudo USERNAME
Write sudo passwd in the terminal - it asks your current password , then it asks a new password for the super user. It seams like Ubuntu allows you to work without a super user privileges on start. But when you need it - you have to make a password. It is the same with Windows administrator politics if you are familiar with it.
sotirov
  • 4,379
Pavlo
You do not have a root password. Open a terminal and type sudo passwd root then hit the enter and set the password.
don.joey
  • 29,392
