I want to install gcc on a ubuntu machine but got the following errors:
   t@lab45:~# apt-get install build-essential
    Reading package lists... Done
    Building dependency tree
    You might want to run 'apt-get -f install' to correct these:
     build-essential : Depends: libc6-dev but it is not going to be installed or
                                libc-dev
                       Depends: gcc (>= 4:4.4.3) but it is not going to be installed
                       Depends: g++ (>= 4:4.4.3) but it is not going to be installed
                       Depends: make but it is not going to be installed
                       Depends: dpkg-dev (>= 1.13.5) but it is not going to be installed
     linux-image-generic-pae : Depends: linux-image-3.2.0-37-generic-pae but it is not going to be installed
    E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
the problem is similar to Install gcc on Ubuntu 12.04 LTS but the solutions there are not workable.
how to deal with this? thanks!
You should make sure that you have the main archive activated in your sources.list file and that no packages are on-hold.
sudo apt-get update
sudo apt-get clean
grep -P 'main&precise-updates' /etc/apt/sources.list
## Here should return something like deb http://ubuntu.mirror.cambrium.nl/ubuntu/ precise-updates main
echo $(dpkg --get-selections | grep hold | awk '{print $1}') install | sudo dpkg --set-selections
sudo apt-get upgrade
sudo apt-get --fix-missing install build-essentials
With this, your installation should be flawless.
Braiam
  • 69,112
