16
I have a secondary hard drive that is mounted as /media/Media and I would like to user a folder called Videos located on that drive that I would like to share the videos located on this folder out via minidlna. I have minidlna working with /home/jonathan/Videos which is on my smaller drive and would like to instead move the videos to the larger drives.
However after I edit my minidlna.conf to point to the /media/Media/Videos folder and do a sudo service minidlna force-reload to reload the database I get a permssions error.
Can someone point me to the correct permissions I need to set on this folder?
OnlyMAJ
  • 234
jjesse
  • 1,115
9 Answers9
17
I tried following the examples in this thread but still could not get it to work. I ended up stumbling on this article here: Running minidlna on Ubuntu and followed it step by step and I now have the media on my second drive being served through minidnla. If any one else struggles I suggest you follow his process.
I have quoted his text in case his page ever disappears.
He installed a service called minidlna which is supposed to allow streaming of media. However, it didn’t like the permissions on his chosen folder. The path is /media/jw/drive2/foo.
jw@FooPC:~$ sudo service minidlna restart
* Restarting DLNA/UPnP-AV media server minidlna
[2014/07/23 21:03:30] minidlna.c:594: error: Media directory "/media/jw/drive2/foo" not accessible [Permission denied]
He pointed it to a folder in his home folder and it liked that just fine, but not the 2nd drive that holds the media.
He tried setting the user as me in the conf file and in the default file. But eventually He discovered he had to set the user as “root” to make it work.
He opened terminal and entered ...
sudo gedit /etc/default/minidlna
...and edited the file...
# User and group the daemon should run as
USER=”root”
#GROUP=”minidlna”
...then saved and back to terminal and entered...
sudo gedit /etc/minidlna.conf
... and edited the file...
# Specify the user name or uid to run as.
user=root
He restarted the service using...
... in terminal and this time there was no error about permissions.
I hope that helps someone as it helped me. If it helps you then please visit his page and leave him a comment like I did so he knows that his page is helping!
UPDATE:
This works straight away but if you power off the machine and then restart it the second drive is not served by the minidnla server until you run:
Getting it to work from bootup is a user-mode drive problem and can be fixed by adding the drive to fstab. The downside is that the system will not boot automatically if the drive is not plugged in, as it will annoyingly demand to retry or ignore before continuing to boot.
An alternative to adding the drive to fstab is to restart the minidlna service at reboot from cron:
sudo crontab -e
then add the next line at the end of the file:
@reboot sleep 60 && sudo service minidlna restart
V Bota
  • 723
Dib
  • 298
10
/media/* is automounted with udisks. If it's NTFS or FAT, only the active user gets access to it, so the minidlna user cannot access it.
It's silly that udisks has the permissions hardcoded, there's a bug report about that: https://bugs.launchpad.net/ubuntu/+source/udisks/+bug/682589
If one mounts the disk with sudo mount /dev/sdb1 /mnt or with /etc/fstab, he can put whatever permissions he wants so that minidlna can read it.
So for home PCs one easy workaround is to edit /etc/default/minidlna, and either specify that minidlna will run as root, or as the user that usually mounts those disks.
USER="root"
#GROUP="minidlna"
If you specified a user account instead of root, also run sudo chown -R user:user /var/lib/minidlna
To rescan the library after the changes, run sudo service minidlna force-reload
And a note to myself, rather than adding media_dir= entries in /etc/minidlna.conf, I prefer creating symlinks under /var/lib/minidlna, e.g.:
sudo ln -sf /media/alkisg/mydisk/Photos /var/lib/minidlna/Photos
...because that way I get an extra level of hierarchy when browsing the media folders in DLNA clients.
alkisg
  • 680
type
sudo chown -R minidlna:minidlna /media/Media
in order to give minidlna ownership of all files and folders contained in Media
then restart and force-rescan the server
IMPORTANT
Start minidlna as root!
sudo minidlna
to rescan library after adding files to your media drive use
sudo service minidlna stop
sudo minidlna -R
to see if it's up
service minidlna status
Daniel W.
  • 3,496
I found another solution: the parent of the media folder has to be accessible to minidlna too. I tried running minidlna as root, and ProtectHome=read-only in the systemctl minidlna.service file but none of this worked.
In my case my videos were in media_dir=V,/srv/share/videos/library.
I had done chmod -R a+xr /srv/share/videos/library but was still getting the Permission Denied message.
After I did chmod o+xr /srv/share/videos it all worked, with user=minidlna.
Hope this helps someone.
I had the same problem, and tried to fix it using this post. But I didn't want root to run the daemon.
Note:
  • I am also connecting a removable disk in userspace as (without using fstab).
  • I am running Ubuntu 16.04.02 LTS
So I edited /etc/default/minidlna to contain
USER=<user>
GROUP=<group>
then /etc/minidlna.conf to contain
user=<user>
I also had to change permissions to allow my user
chown <user>:<group> /var/cache/minidlna
chown <user>:<group> /run/minidlna
Then restart the service
smido
  • 185
I was trying to run MiniDLNA as an alternative storage area for HDHomeRun RECORD (using NAS config in HDHomeRun SETUP).
I thought Samba was conflicting when I rebooted and my DLNA server was no longer working. Turns out I never set firewalld to have an open port 8200, I had just turned it off and forgotten to disable the service (probably thinking I would do it properly later and forgetting).
I'm using Fedora 27, BTW.
For some reason MiniDLNA reports media directory as being not accessible if your port is not open. Example --
Before turning off firewalld:
# systemctl status minidlna
systemd[1]: Started MiniDLNA is a DLNA/UPnP-AV server software.
minidlna.c:620: error: Media directory "/home/local/Downloads" not accessible [Permission denied]
minidlna.c:620: debug: Using locale dir '/usr/share/locale' and locale langauge en_US.UTF-8/en_US.UTF-8
minidlna.c:1048: warn: Starting MiniDLNA version 1.2.1.
After turning off firewalld:
<root xmlns="urn:schemas-upnp-org:device-1-0"><specVersion><major>1</major><minor>0</minor></specVersion><dev
minidlnad[4401]: MS_MediaReceiverRegistrar</eventSubURL><SCPDURL>/X_MS_MediaReceiverRegistrar.xml</SCPDURL></service></service
minidlna.c:1302: debug: HTTP connection from 192.168.1.190:65260
minidlnad[4401]: clients.c:332: debug: Client found in cache. [Generic UPnP 1.0/entry 1]
minidlnad[4401]: upnphttp.c:889: debug: HTTP REQUEST: GET /icons/sm.png HTTP/1.1
minidlnad[4401]: Connection: Keep-Alive
minidlnad[4401]: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
minidlnad[4401]: Host: 192.168.1.186:8200
minidlnad[4401]: [1B blob data]
minidlnad[4401]: upnphttp.c:1391: debug:
Sending small PNG icon
I'm not sure why it would report the media directory as being inaccessible because of a port being blocked, that seems like strange behavior to me. But disabling the firewall was all I did for it to start working again.
I ran into the same problem on a NAS I try to create. I think the /etc/init.d/minidlna script should not:
if [ -z $GROUP ]; then
   GROUP=$USER
fi
But do a
if [ -z $GROUP]; then
   GROUP=$(id -gn $USER)
fi
Because the primary group of the user may differ from the user. Especially when you want users to share you want a group they share to be the primary group of minidlna too.
muru
  • 207,228
I realize this is an older question but if you fstab the external drive with the defaults,user as options and then sudo chown -cR $USER:minidlna /media/(your_mount point_here). This should maintain the ownership and group through reboots as well as give the default minidlna group that the server is run with group access to the files.
dginsd
  • 601
-1
To let miniDLNA rescan its library we may issue the following commands:
sudo service minidlna stop    # stop minidlna
sudo -u minidlna minidlna -R  # rescan the library
sudo service minidlna start   # restart minidlna
Note that with default library settings the second line needs to be run under the user minidlna in order to let minidlna have access to this library later.
Depending on your settings you may have defined a location for the library other than default /var/lib/minidlna. Then we may need different permissions.
Takkat
  • 144,580
