I have tried tons of different "solutions" to no avail. First off I'm running 64-bit 12.04 LTS, and I'm using a USB mouse that freezes after 20 minutes or so? Everything else will work except for the mouse.
  1. Mouse freezes after 20 minutes of use
    greg@ubuntu:~$ synclient TouchpadOff=0
    Couldn't find synaptics properties. No synaptics driver loaded?
  2. Ubuntu 12.04/12.10 Keeps on Freezing
    It just didn't work after I installed the kernels.
  3. Upgrade your graphics card drivers
    Again this did not work.
Thanks in advance, tell me if you need anymore info at all.
System info
Update: I just tried to log off while it was frozen and that did not fix the problems as it did for others. I'm going to do my updates and see how that will work. I will post an update if it works.
I have had problems using the mouse in a USB3 port, solved when I moved it over to the USB2 port.
