I am new to ubuntu. So I tired to install a software by typing the 'make install'. this error is occurred. Please help me.
cd src && make CC='gcc' CPPFLAGS='' DEFS='-DHAVE_CONFIG_H -DSYSTEM_WGETRC=\"/usr/bin//etc/wgetrc\" -DLOCALEDIR=\"/usr/bin//share/locale\"' CFLAGS='-O2 -Wall -Wno-implicit' LDFLAGS='' LIBS='' prefix='/usr/bin/' exec_prefix='/usr/bin/' bindir='/usr/bin//bin' infodir='/usr/bin//info' mandir='/usr/bin//man' manext='1' install.bin
make[1]: Entering directory `/home/praneethpj/wget1.5.3/src'
gcc -O2 -Wall -Wno-implicit  -o wget  cmpt.o connect.o fnmatch.o ftp.o ftp-basic.o ftp-ls.o ftp-opie.o getopt.o headers.o host.o html.o http.o init.o log.o main.o md5.o netrc.o rbuf.o recur.o retr.o url.o utils.o version.o
/usr/bin/ld: h_errno: TLS definition in //lib/libc.so.6 section .tbss mismatches non-TLS reference in ftp.o
//lib/libc.so.6: could not read symbols: Bad value
collect2: ld returned 1 exit status
make[1]: *** [wget] Error 1
make[1]: Leaving directory `/home/praneethpj/wget1.5.3/src'
make: *** [install.bin] Error 2
sudo apt-get install firefox
this is through terminal
if you want to install it via GUI then ubuntu software source is a good Repositories type what ever software you want to install and install,another way is through synaptic package manager for more details on this read http://www.wikihow.com/Install-Software-in-Ubuntu
3bu1
  • 344
To install a software using the source code, as you're trying to do, normally requires 3 commands. Following are the steps, you need to follow:
  • Move to the directory containing the source code.
cp /path/to/source/code
  • Look for file named README or INSTALL. The file, if present, would probably contain install instructions.
Otherwise, you can also look at the website from where you downloaded the source to get the information.
  • If you don't want to do so, which I do recommend doing, run the following commands:
    ./configure
    make
    sudo make install
  • You might get error at ./configure, which would mean that either configure file is not present, in which case you should read the installation instructions, or there can be some dependencies which need to be installed first.
Or, of course, they can be just some warnings that won't mean much depending on the use case.
green
  • 14,406
