18
I've read through man pngcrush and it seems that there is no way to crush a PNG file and save it over the original. I want to compress several folders worth of PNGs so it would be useful to do it all with one command!
Currently I am doing pngcrush -q -d tmp *.png then manually cut-pasting the files from the tmp directory to the original folder. So I guess using mv might be the best way to go? Any better ideas?
Jorge Castro
  • 73,717
Since version 1.7.22, pngcrush has an overwrite option.
Try
See Changelog for more information:
Version 1.7.22  (built with libpng-1.5.6 and zlib-1.2.5)
  Added "-ow" (overwrite) option.  The input file is overwritten and the
    output file is just used temporarily and removed after it is copied
    over the input file..  If you do not specify an output file, "pngout.png"
    is used as the temporary file. Caution: the temporary file must be on
    the same filesystem as the input file.  Contributed by a group of students
    of the University of Paris who were taking the "Understanding of Programs"
    course and wished to gain familiarity with an open-source program.
Jan
  • 405
17
All on one line:
for file in *.png; do pngcrush "$file" "${file%.png}-crushed.png" && mv "${file%.png}-crushed.png" "$file"; done
should do it.
(Though so far in my own tests, less than half of the pngs I tested pngcrush on were smaller afterwards, so color me unimpressed.)
Eliah Kagan
  • 119,640
frabjous
  • 6,601
