56
A software upgrade broke, among other things, mysql and I have not been able to get it back up yet.
Suspected cause: I had a near-full boot disk; the upgrade filled up the disk before completing and thus left everything in a mess. I have given the system more disk and moved /var to its own partition. I am still unsuccessfully trying to revive mysql.
Below is what I attempted so far (all as root). First, mysql does not start (443). Attempts to fix (444, 445) fail. Attempts to remove mysql and (?) apparmor fail (446, 7, 8). A more energetic attempt to remove mysql seems to succeed (449) and the previous errors are no longer seen (450, 1, 2). Mysql can't be reconfigured because it's no longer there (453) but attempting to reinstall it gives back the old error messages and we're back to square one (454).
I also checked this question (even though in my case it did not break because of an upgrade to 12.04: it was already working on 12.10) Fixing broken myslq-server package after upgrade to 12.04 and tried the suggestions in there (458, 461, 462) to no avail.
What else should I do?
This is on 3.5.0-25-generic #39-Ubuntu SMP Mon Feb 25 18:26:58 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
    443  service mysql start
         start: Job failed to start
    444  dpkg-reconfigure mysql-server-5.5
         /usr/sbin/dpkg-reconfigure: mysql-server-5.5
         is broken or not fully installed
    445  apt-get -f install
         Setting up mysql-server-5.5 (5.5.29-0ubuntu0.12.10.1) ...
         invoke-rc.d: initscript mysql, action "start" failed.
         dpkg: error processing mysql-server-5.5 (--configure):
         subprocess installed post-installation script
         returned error exit status 1
         dpkg: dependency problems prevent configuration of
         mysql-server:
         mysql-server depends on mysql-server-5.5; however:
         Package mysql-server-5.5 is not configured yet.
         dpkg: error processing mysql-server (--configure):
         dependency problems - leaving unconfigured
         No apport report written because the error message
         indicates its a followup error from a previous failure.
           mysql-server-5.5
           mysql-server
    446  apt-get remove mysql-server
         Removing mysql-server ...
         No apport report written because MaxReports is reached already
           mysql-server-5.5
    447  apt-get remove apparmor
         Package 'apparmor' is not installed, so not removed
         0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
         1 not fully installed or removed.
         After this operation, 0 B of additional disk space will be used.
           mysql-server-5.5
    448  apt-get remove mysql-server
         Reading package lists... Done
         Building dependency tree
         Package 'mysql-server' is not installed, so not removed
           mysql-server-5.5
    449  dpkg -r mysql-server-5.5
         (Reading database ... 322156 files and directories
         currently installed.)
         Removing mysql-server-5.5 ...
         Processing triggers for man-db ...
         Processing triggers for ureadahead ...
    450  apt-get remove mysql-server
    451  apt-get remove apparmor
    452  apt-get -f install
    453  dpkg-reconfigure mysql-server-5.5
         /usr/sbin/dpkg-reconfigure: mysql-server-5.5 is broken
    454  apt-get install mysql-server
         The following extra packages will be installed:
           mysql-server-5.5
         Suggested packages:
           tinyca mailx
         The following NEW packages will be installed:
           mysql-server mysql-server-5.5
         0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
         Need to get 0 B/8,851 kB of archives.
         After this operation, 32.8 MB of additional disk space
         will be used.
         Do you want to continue [Y/n]?
         Preconfiguring packages ...
         Selecting previously unselected package mysql-server-5.5.
         (Reading database ... 322081 files and directories
         Unpacking mysql-server-5.5 (from
         .../mysql-server-5.5_5.5.29-0ubuntu0.12.10.1_amd64.deb) ...
         Selecting previously unselected package mysql-server.
         Unpacking mysql-server (from
         .../mysql-server_5.5.29-0ubuntu0.12.10.1_all.deb) ...
         dpkg: dependency problems prevent configuration of mysql-server:
           mysql-server-5.5
           mysql-server
    458  apt-get remove --purge mysql-server
         The following packages will be REMOVED:
           mysql-server*
         0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
         2 not fully installed or removed.
         After this operation, 116 kB disk space will be freed.
         (Reading database ... 322159 files and directories
           mysql-server-5.5
    461  touch /etc/apparmor.d/local/usr.sbin.mysqld
         (no output)
    462  service mysql start
st01
  • 1,113
7 Answers7
112
First, remove MySQL:
sudo apt purge mysql-server mysql-client mysql-common
sudo apt autoremove
sudo mv -iv /var/lib/mysql /var/tmp/mysql-backup
sudo rm -rf /var/lib/mysql*
Then reinstall:
sudo apt update
sudo apt install mysql-server
mysqld --initialize
sudo /usr/bin/mysql_secure_installation
Joren
  • 5,074
14
In Ubuntu 16.04 the way to fix it in my case was (please backup DBs first, databases will be lost):
sudo apt remove --purge mysql-server mysql-client mysql-common
sudo apt autoremove
(Somehow, my previous calls to apt purge mysql-server didn't seem to succeed. I thought that apt purge foo was equivalent to apt remove --purge foo...)
rubo77
  • 34,024
  • 52
  • 172
  • 299
knocte
  • 1,016
  • 25
12
I was getting the exact same errors and tried most of the steps you did, with the same results. The following finally worked for me.
apt-get purge mysql-server mysql-client mysql-common mysql-client-5.5 mysql-server-5.5
After that, mysql installed normally.
Tom Damon
  • 477
I am not sure what was the case for me, but the other solutions did not work, it kept giving an error. I tried this apt-get purge mysql-*, then autoremove and autoclean. After that installation was fine.
Be sure to backups your databases, the above command might delete them as well
dav
  • 131
For version MySQL 5.7 I removed MySQL as described before:
sudo apt autoremove
And installed it with help:
sudo apt-get update
sudo apt-get install mysql-server
To test if everything works:
systemctl status mysql.service
source
If you just run
sudo apt-get update
it will update mysql and this fixed the problem that i had after updating to 16.04 lts.
Or just run
sudo apt-get install lamp-server^
to update all of the server packages.
edwinksl
  • 24,109
-5
Install phpMyAdmin from the default Ubuntu repositories. Then run:
dpkg --configure mysql-server-5.5
apt-get autoremove
apt-get autoclean
apt-get update
service mysql restart
Eric Carvalho
  • 55,453
