I'm trying to get multi-touch gestures working on my Dell XPS 15. Two finger scrolling works but three or four finger gestures do not. I know that the touchpad is capable of multi-touch gestures because it works fine in Windows. I've tried several things already:
  • Installing touchegg from the repository
  • Installing touchegg from source
  • Installing Sputnik kernel and policykit updates from Sputnik PPAs
The first fails with a segmentation fault when run, the second gives errors during compile about missing files, and the third installed fine but nothing changed. Compilation errors can be seen here.
Nimble
  • 1,139
Try this solution.
Install xserver-xorg-input-multitouch and xserver-xorg-input-synaptics
sudo apt-get update
sudo apt-get install xserver-xorg-input-multitouch
sudo apt-get install xserver-xorg-input-synpatics
It has solved touchpad issues on other brand name laptops, don't know about Dell.
RCF
  • 2,127
In ubuntu 14.04 all working fine for me , i suggest you to upgrade to ubuntu 14.04 or try find out whats ubuntu 14.04 using that causing the difference . .
If you're using Ubuntu Unity, 3- and 4-touch gestures are reserved to the window manager (Unity), and the 3-finger window management gestures are disabled for touchpads. I'm no longer clear on the rationale behind disabling them for touchpads, it was done in early in 2013.
