How does one discover which command to run to install a piece of software?
For example, if I wanted to know the command to run to install VirtualBox, how do I know that I should run sudo apt-get install virtualbox-4.2, and not sudo apt-get install XYZ?
Flimm
  • 44,031
Kraken
  • 409
When you don't want to use the search field in the Ubuntu Software Center you can search the packages via apt with this command: sudo apt-cache search virtualbox
You will get a list of found packages and now you can install it by typing the right package i.e. sudo apt-get install virtualbox-4.2
prophecy201
  • 2,760
  • 17
  • 22
if you do not know which command check the Ubuntu software center first. because virtualbox is available on the Ubuntu software center.
or check virtual box official website click here
they are saying sudo apt-get install virtualbox-4.2
kay
  • 145
