I often find that I need to figure out the command to execute a certain application, such as an Alarm Clock application or the System Monitor. However, many of the actual CLI commands to run these are not directly evident. What I usually do is just go to the Ubuntu Software Center, then search for the application's "common name" and hence find its package/command name. I would like to know if there is an easier or more efficient way of doing this.
I was wondering if there is a command similar to xprop, where clicking on an open (graphical) application would output its command in the terminal. In other words, I am interested in a graphical way of finding an application's command.
For example, if I run such a command and click on System Monitor, the terminal would output gnome-system-monitor, etc. Thanks.
PS. If a solution is not currently available, I would be interested in writing my own script with this functionality. I only know basic bash, however. I realize that should probably go under a separate question, but I'm just throwing it out there.
