In my ubuntu 12.10 it didn't detect my graphic card. When I check the graphics in system settings>details it says none
I've downloaded my driver installer from the NVIDIA website, make it executable, then it ran but it say I doesn't install on a X server..
I read in a blog that I have to download drivers via the software center called jockey. After the installation I couldn't find my driver in the list..plus the problem it mentioned if I messed up then it will mess up my boot.
Can't I just use the file I got from nvidia to install it? Speaking of which is it necessary here since I don't play games here and would go for vmware and install my old windows OS there and play the game there instead.
Thanks
First put the downloaded NVIDIA driver in a folder which is easily accessible, for example on the Desktop.
Then switch to a virtual terminal using Ctrl + Alt + F1.
Enter your username and password to login.
Navigate to the folder which you've placed your driver in it, in this case it is Desktop:
cd ~/Desktop/
Now add the permission : execute to the installation file:
sudo chmod +x NVIDIAdriver*.run
replace NVIDIAdriver* with the actual name.
Now stop the X server as the error also mentions the same thing:
sudo service lightdm stop
Now you can go ahead and install the driver simply by typing this command:
sudo ./NVIDIAdriver*.run
Again replace NVIDIAdriver* with the drivers actual name.
Also, graphic cards don't support visualization yet, so you won't get any good performance with WMware.
hg8
  • 13,582
