28
I'm currently using precise. I need to upgrade a certain package (namely bind9 and it's dependencies) to a newer version, which is currently found in raring (alfa at the time of writing this). How to do it ?
What will happen if I just add to my sources.list:
deb http://archive.ubuntu.com/ubuntu raring main
Will the next apt-get update / apt-get upgrade, upgrade most of my system to raring then ?
Sandman4
  • 1,207
If you want to mix repositories like that you should use pinning.
See https://help.ubuntu.com/community/PinningHowto for details.
When pinning, you install a single package and as few dependencies as possible.
Without pinning, sudo apt-get upgrade will update (upgrade) many or all your packages and very likely will cause breakage.
In general, unless you have a lot of experience with apt, mixing repositories, even with pinning is inadvisable.
Better to find a ppa or use backports.
My advice is that you use Craven's ppa.
https://help.ubuntu.com/community/UbuntuBackports
IMO, if a package is not available, I agree with the advice to build from source as, IMO, it is less likely to cause irreparable harm to the system.
Panther
  • 104,528
Presumably it will upgrade all the packages to the newest version found in the raring repository.
You should try adding a specific PPA for the bind9 package.
David
  • 907
