I want to have strong DNS cache server on my local host (server). So I need to change name server to my localhost.
  1. How can I change it? byt this config it seems I must don't change it via editor so how can I change it?
    root@asqar# cat /etc/resolv.conf
    # Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
    #     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
    nameserver 4.2.2.4
    search asqar.net
  2. I'm using bind9 how can I set the DNS cache, any configure ?
Braiam
  • 69,112
If you want a DNS cache on your local machine, use dnsmasq, not BIND.
Unless you really need a local iterative nameserver, de-install BIND.
sudo apt-get purge bind9
Now for dnsmasq. There are two ways of using dnsmasq.
1: If you are using NetworkManager to manage networking then you already have the dnsmasq-base package installed; you just have to enable the NetworkManager-controlled dnsmasq instance by editing NetworkManager.conf
sudo gedit /etc/NetworkManager/NetworkManager.conf
and ensuring that the line
dns=dnsmasq
is present. Next enable caching in this dnsmasq instance. Create a new configuration file called, e.g., local
sudo gedit /etc/NetworkManager/dnsmasq.d/local
and add the single line
cache-size=150
to change the default cache size from zero. Then restart network-manager
sudo restart network-manager
which will also start or restart the NetworkManager-controlled dnsmasq instance using the new nonzero cache size.
This only works in Ubuntu 12.10 or later. In Ubuntu 12.04 the NetworkManager-controlled dnsmasq configuration cannot be customized and the cache size is zero.
2: The other way of using dnsmasq is to run it as a server. To do this, install the dnsmasq package and configure it by editing /etc/dnsmasq.conf and setting cache-size to a value greater than zero.
In Ubuntu 12.10 the dnsmasq server will forward queries to external nameservers if the NetworkManager-controlled dnsmasq instance is disabled and will forward queries to the NetworkManager-controlled dnsmasq instance at the address 127.0.1.1 if the NetworkManager-controlled dnsmasq instance is enabled.
In Ubuntu 12.04 the same thing can be achieved but some additional manual configuration steps are required because in Ubuntu 12.04 the NetworkManager-controlled dnsmasq instance listens at 127.0.0.1 which conflicts with dnsmasq server in its default configuration.
jdthood
  • 12,625
this may be helpful, I don't think it will work as is on ubuntu but you should be able to adapt it easily.
A simple named.conf which forwards all DNS queries to another nameserver, and caches the answers for possible reuse. Tested under OpenBSD 4.7 BETA with
$ named -v
BIND 9.4.2-P2
This type of configuration is useful to minimize the repeating nameserver queries issued when surfing the web. Not only for your notebook or laptop using wireless connections, but also for a department that wishes to make use of a LAN/WAN link efficiently.
The Access Control List (acl) limits useage of this forward-only nameserver to my local 192.168.222.0/24 subnet.
The queries are forwarded to a dnscache namerver running on my OpenBSD firewall at 192.168.222.10.
The cache size is limited to two MB, which probably is too much for a notebook or laptop. The comments show how to calculate this
<p>amount in bytes using bc(1), the unlimited precision calculator.</p>
// Caching and forward only configuration
// Access Control List
acl  clients    {
    192.168.222.0/24  ;
options {
    forward only ;
    forwarders { 192.168.222.10 ; } ;
    allow-query { clients ; } ;
    // max-cache-size is in bytes : echo '2 * 1024^2' | bc
    max-cache-size 2097152 ;
    empty-zones-enable yes;
# After editing this file please use 'named-checkconf' to validate!
To enable this under OpenBSD, assuming the above configuration has been saved as /var/naned/etc/caching-forward-only.conf, you have to add the following to /etc/rc.conf.local:
named_flags='-4 -c /etc/caching-forward-only.conf'
Note that applications use the /etc/resolv.conf to find out which name server they should use. So for a departmental nameserver, all clients should have the iP address of that name server in /etc/resolv.conf
<p>For my small department in the garage, the clients have the following
in /etc/resolv.conf</p>
nameserver 192.168.222.25
reference : http://www.daemonforums.org/showthread.php?t=4471
or try this, seems more Ubuntu-centered : http://soledadpenades.com/articles/ubuntu/using-bind-as-a-local-caching-name-server/
maazza
  • 271
