I need to boot my computer with nolapic noapic and acpi=off. I can do it with the liveCD but unless the flags are applied at boot on the harddrive the kernel panics and the system doesn't boot (so no graphics tools to install). What's the best way to apply these settings on a fresh installation. I used to chroot into the install and tag them that way. For the last two releases I've not been able to do this :(.
Asked
Active
Viewed 144 times
If it will not boot at all after the install, first go ahead and do the install.
Then, before rebooting or from a live CD, mount the install and make the adjustments.
First mount your Ubuntu partition at /mnt, I am assuming /dev/sda1, adjust accordingly
sudo mount /dev/sda1 /mnt
Edit /etc/default/grub in the /mnt partition
gksu gedit /mnt/etc/default/grub
Look for the line with boot options
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash reboot=bios"
Add in your options
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash reboot=bios acpi=off"
Update grub. Again I am assuming you are installing grub into the first hard drive.
sudo grub-install --root-directory=/mnt /dev/sda
Panther
- 104,528
