When i attach my Notebook (Nvidia Geforce GT 240M) to my Panasonic-TV via HDMI, both screens are activated. I use Nvidia-Driver Version 260.19.06.
I wonder how to deactivate my notebook display automatically or with one Script and switch to the external Monitor when attached. The TV needs an overscan-correction of 100px to display the whole screen.
I also want to close the notebook without deactivating the external monitor, what still happens now.
Is this possible?
bdr529
  • 3,098
Here is a simple script to turn off notebook display when external monitor is connected:
if xrandr -q | grep -q  "HDMI connected"; then
  xrandr --output LVDS --off --output DFP1
else
  xrandr --output VGA --off --output LVDS
fi
If you want to set a specific resolution, you may add "--mode 1680x1050" in the end of xrandr lines. Output offset can be added using "--pos 100x0" command.
The script can be bound to any unused key combination or executed on startup using "System>>Preferences>>Startup Applications"
Note, that "DFP1" may be different on your system - check out 'xrandr -q' output with external monitor attached
Graphical gtk tool to do the same thing: grandr. It's in the official repos so you can
sudo apt-get install grandr
Zanna
  • 72,312
nejode
  • 501
So at least i found a solution for my problem.
What i found out is, that xrandr is nor supported by the propietary NVIDIA-drvers. Xrandr even can't detect my displays. The nvidia tool nvidia-settings can be used from command line, but is not capable to activate or deactivate screens.
To switch displays you can use the tool disper: disper on launchpad It's a command line tools, wich exactly fits my problem an is easy to use.
Some example scripts for automatic switching at startup can be found here: Ubuntuusers.de wiki
Hope, that this may help someone.
bdr529
  • 3,098
