I just installed Ubuntu 12.10 on a Acer Aspire One ZG5 (AOA 110), then Skype, and I can't make the microphone work. I tried this method with alsamixer
https://help.ubuntu.com/community/AspireOne522#Microphone
but it doesn't works. The sound is not recognized by alsamixer, nor by the sound settings. I tried to make a test call on skype, but I can't hearmy voice back.
I read that previous versions of Ubuntu had some issues with the mic, maybe I have to debug something...
I hope you can help me
Rafa
I had an Acer ZG5 with this issue on 12.10. To fix it I installed Pulse Audio Manager, PulseAudio Volume Control PulseAudio Volume Meter(capture) and Pulse Audio Volume Metere (playback). You then at least could see the settings... After this, the trick is to turn down the volume on ONE of the microphone channels (Left or right doesn't matter) to zero, and keep the other one turned on.
This worked for me..
Also managed to get the fancontrol by applying acerhdf fixes.. do a google on acerhdf ZG5, then I set the fan to come on at 55 deg off at 50 deg...
Now works A OK..
Bob T
