I have seen some similar questions but none that I have seen have resolved my issue. An error occured durring a kernel upgrade on Ubuntu 12.04 from linux-image-3.2.0-36-generic to linux-image-3.2.0-38-generic. A Kernel Panic occurs on boot while booting with 3.2.0-38.
Booting in under `3.2.0-36 the system starts normally. However when I attempt to remove clean or configure the affected kernel package it throws the following error:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
initramfs-tools : Depends: initramfs-tools-bin (< 0.99ubuntu13.1~) but 0.99ubuntu13.1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Attempting sudo apt-get -f install, meets with no success citing dependency and configuration issues, after the package retrevial:
dpkg: dependency problems prevent configuration of initramfs-tools:
initramfs-tools depends on initramfs-tools-bin (<< 0.99ubuntu13.1~); however:
Version of initramfs-tools-bin on system is 0.99ubuntu13.1.
dpkg: error processing initramfs-tools (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-image-3.2.0-38-generic:
linux-image-3.2.0-38-generic depends on initramfs-tools (>= 0.36ubuntu6); however:
Package initramfs-tools is not configured yet.
dpkg: error processing linux-image-3.2.0-38-generic (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of casper:
casper depends on initramfs-tools (>= 0.92bubuntu55); however:
dpkg: error processing casper (--configure):
initramfs-tools
casper
I receive similar errors when running dpkg -- configure -a, apt-get -f dist-upgrade and apt-get -f autoremove.
Any ideas on what exactly corrupted during the kernel upgrade and how I can roll back my kernel version without using Apt-get or Dpkg?
