-1
I have installed Ubuntu 12.04 inside windows installer in my system, partition E. I just cut Ubuntu and paste into another location and after that, Ubuntu is not working. Whenever I try to install, it shows following error message:
An error occurred: Error executing command
command=C:\Windows\sysnative\bcdedit.exe/set {ccdaaf92-e976-11e1-a206-dde85cb781c2}device partition=E: retval=1 stderr=An error has occured setting the element data. The request is not supported.
<p>stdout=</p>
<p>For more information, please see the log file:
c:/users\advent~1\appdata\local\temp\wubi-12.04-rev272.log</p>
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
suresh
Your question has the answer in itself! you shouldn't do that. I you want to change the location, test this:
  1. Install another instance of Ubuntu where you like.
  2. Replace new Ubuntu files with old ones.
I haven't tested this myself.
Mostafa Shahverdy
  • 5,342
  • 22
  • 34
