I bought a Sony Vaio with windows 7 preinstalled. Now I have a lot of problem installing Ubuntu, but I was able to install Ubuntu, but now the brightness doesn't work as needed.
With lspci I get:
VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Thames [Radeon 7500M/7600M Series]
How can I solve this ?
Too much light is hurting my eyes, the brightness is at maximum level and I use the computer to work.
jobin
  • 28,567
pablo
Try installing xbacklight using apt-get (sudo apt-get install xbacklight). Then try this from the terminal, too: xbacklight -20. If brightness is decreased when running this last command, then this solution might work for you: How to use xbacklight with brightness keys in a VAIO (you'll need to edit some of the paths inside the script).
Hope it helps.
picheto
  • 201
