All problems begin when I was trying to install graphics card driver. My desktop wanished. I paniced and reinstalled (with apt-get) a lot of packages including Ubuntu desktop, Unity, Xserver, etc. I solved the problems with missing desktop and sidebar but from that day on I keep getting following errors when I try to install almost anything using apt-get install.
Reading package lists... Done
Building dependency tree
 totem : Depends: totem-common (= 3.0.1-0ubuntu21) but 3.0.1-0ubuntu21.1 is to be   installed
Recommends: totem-plugins but it is not going to be installed
Recommends: totem-mozilla but it is not going to be installed
What went wrong and what to do to get the apt-get install working again?
I would try to fix dependencies by apt-get removeing problematic things and then apt-get install the thinks I want. But it wants me to uninstall a lot of things. Following the unmet dependencies i got to package libgnutls26.
sudo apt-get remove libgnutls26
writes following
Building dependency tree...
Reading state information...
The following packages were automatically installed and are no longer required:
  libopenal1:i386 libjna-java libsdl-ttf2.0-0 jsvc libdb5.1-java-gcj
  libdb-je-java libxfixes3:i386 junit4 gcj-4.6-jre-lib ttf-umefont
  libboost-filesystem1.46.1 libecj-java libgraphicsmagick3 libtorque2
  libogre-1.7.4 libxcomposite1:i386 liboro-java libldap-2.4-2:i386
  libv4l-0:i386 libjoda-time-java libnb-javaparser-java gnome-exe-thumbnailer
  eclipse-platform-data libroken18-heimdal:i386 gcj-4.6-base libxerces2-java
  libcxsparse2.2.3 libgphoto2-port0:i386 libgcj-bc libemma-java libfreeimage3
  libjtidy-java libjzlib-java libglpk0 libarpack2 libpg-java libicu4j-java
  libcholmod1.7.1 libaspectj-java libfreemarker-java libservlet2.4-java
  libswt-cairo-gtk-3-jni libcommons-beanutils-java libosgi-compendium-java
  libbetter-appframework-java libsane:i386 junit odbcinst1debian2
  libsdl-mixer1.2 cmake-data libtinyxml2.6.2 libxxf86vm1:i386 bsh-gcj
  libboost-system1.46.1 libsac-java-gcj libdb-java libgl1-mesa-dri:i386
  empathy-common libxcb-glx0:i386 libasn1-8-heimdal:i386
  libnb-platform-devel-java libgl1-mesa-glx:i386 libwebkitgtk-1.0-common
  libgeronimo-jpa-2.0-spec-java libapr1 libxslt1.1:i386 javahelp2
  libcommons-cli-java libcapi20-3 libcapi20-3:i386 libx11-xcb1:i386
  libcglib-java libglapi-mesa:i386 libumfpack5.4.0 libcommons-logging-java
  odbcinst jetty libgssapi3-heimdal:i386 libcommons-compress-java
  libcegui-mk2-0.7.5 libv4lconvert0:i386 apache2-utils libgcj12
  libccolamd2.7.1 libdb5.1-java unixodbc libbytelist-java
  libsimple-validation-java libicu4j-4.4-java libsvnkit-java
  libfelix-framework-java libjavascriptcoregtk-1.0-0 smc-data
  libosgi-foundation-ee-java libnb-platform13-java ant wine-gecko1.4
  wine-gecko1.4:i386 libstringtemplate-java libwind0-heimdal:i386 aspectj
  libjsch-java bsh libparpack2 libeasymock-java winetricks jarwrapper
  libxml-commons-resolver1.1-java libfltk1.1 ant-optional libxinerama1:i386
  libsilly libgif4:i386 libsac-java libjcodings-java dkms libapache-pom-java
  libcolamd2.7.1 libopenmpi1.3 libxml-commons-external-java icoutils
  libosgi-core-java libieee1284-3:i386 libgraphicsmagick++3
  libhdf5-serial-1.8.4 octave3.2-common libflute-java sat4j libantlr-java
  libcommons-el-java libjvyamlb-java libnb-org-openide-util-java
  libboost-thread1.46.1 libtrilead-ssh2-java libxpm4:i386 libusb-0.1-4:i386
  libzzip-0-13 libcommons-httpclient-java libfelix-main-java
  libhcrypto4-heimdal:i386 libhx509-5-heimdal:i386 libgd2-xpm:i386
  libheimbase1-heimdal:i386 libslf4j-java libcommons-daemon-java libnuma1
  libnetx-java libasm3-java libamd2.2.0 libswing-layout-java libregexp-java
  libgnomeui-common libmysql-java libswingx1-java libibverbs1
  libnb-absolutelayout-java fastjar libjemmy2-java libois-1.3.0 libjasper-java
  libmpg123-0 libmpg123-0:i386 libdb4.8 libsasl2-2:i386 libgsoap1
  libcommons-codec-java libcommons-lang-java libhamcrest-java liblucene2-java
  libgeronimo-osgi-support-java libheimntlm0-heimdal:i386 libequinox-osgi-java
  libxdamage1:i386 libcommons-parent-java libcommons-collections3-java
  libbeansbinding-java libgcj-common libodbc1 libcommons-net1-java
  libexif12:i386 libglu1-mesa:i386 fonts-droid libopenjpeg2
  libbonoboui2-common libcommons-digester-java libbindex-java libxcursor1:i386
  libini4j-java libjetty-java libsasl2-modules:i386 libaprutil1 libqrupdate1
  libqhull5 antlr3 libxerces-c3.1 libjline-java libxrandr2:i386 libcrystalhd3
  libnb-org-openide-modules-java libdevil1c2 libswt-glx-gtk-3-jni
  libpostgresql-jdbc-java libgnomecanvas2-common libltdl7:i386 ttf-droid
  libkrb5-26-heimdal:i386 libganymed-ssh2-java
  libnb-org-openide-util-lookup-java libllvm3.0:i386 libgphoto2-2:i386
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
  activity-log-manager-control-center aisleriot alacarte apport-gtk
  apt-transport-https aptdaemon apturl bamfdaemon baobab bluez-cups brasero
  brasero-cdrkit chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg
  cmake compiz compiz-fusion-plugins-extra compiz-gnome compiz-plugins-extra
  compiz-plugins-main compiz-plugins-main-default compizconfig-backend-gconf
  compizconfig-settings-manager cups cups-bsd cups-client cups-filters
  cups-pk-helper cups-ppdc curl dconf-tools default-jre default-jre-headless
  deja-dup eclipse eclipse-jdt eclipse-pde eclipse-platform eclipse-rcp
  emacs23 empathy eog evince evolution-data-server file-roller firefox
  firefox-globalmenu firefox-gnome-support flashplugin-installer gcalctool
  gconf-service gconf-service-backend gconf2 gedit geoclue
  geoclue-ubuntu-geoip ghex ghostscript ghostscript-cups ghostscript-x ginn
  gir1.2-appindicator3-0.1 gir1.2-caribou-1.0 gir1.2-clutter-1.0
  gir1.2-dbusmenu-gtk-0.4 gir1.2-gconf-2.0 gir1.2-gkbd-3.0
  gir1.2-gnomebluetooth-1.0 gir1.2-gtk-2.0 gir1.2-gtk-3.0 gir1.2-gtksource-3.0
  gir1.2-launchpad-integration-3.0 gir1.2-mutter-3.0 gir1.2-panelapplet-4.0
  gir1.2-peas-1.0 gir1.2-rb-3.0 gir1.2-soup-2.4 gir1.2-ubuntuoneui-3.0
  gir1.2-vte-2.90 gir1.2-webkit-3.0 gir1.2-wnck-3.0 git gksu glib-networking
  gnome-applets gnome-applets-data gnome-bluetooth gnome-contacts
  gnome-control-center gnome-disk-utility gnome-font-viewer gnome-games-data
  gnome-icon-theme gnome-icon-theme-full gnome-icon-theme-symbolic
  gnome-keyring gnome-media gnome-nettool gnome-online-accounts gnome-orca
  gnome-panel gnome-panel-data gnome-power-manager gnome-screensaver
  gnome-screenshot gnome-session gnome-session-bin gnome-session-canberra
  gnome-session-fallback gnome-settings-daemon gnome-shell gnome-sudoku
  gnome-system-log gnome-system-monitor gnome-terminal gnome-terminal-data
  gnome-themes-standard gnome-tweak-tool gnome-user-guide gnome-user-share
  gnomine gnuplot gnuplot-x11 gparted gs-cjk-resource gstreamer0.10-gconf
  gstreamer0.10-nice gstreamer0.10-plugins-bad gstreamer0.10-plugins-good
  gtk2-engines gtk2-engines-murrine gtk3-engines-unico gucharmap gvfs-backends
  gwibber hardinfo hplip humanity-icon-theme ibus ibus-gtk ibus-gtk3
  ibus-pinyin ibus-table icedtea-6-jre-cacao icedtea-6-jre-jamvm
  indicator-applet-complete indicator-application indicator-appmenu
  indicator-datetime indicator-messages indicator-power indicator-printers
  indicator-session indicator-sound indicator-status-provider-mc5
  indicator-status-provider-pidgin jockey-common jockey-gtk kerneloops-daemon
  landscape-client-ui-install language-selector-gnome libappindicator1
  libappindicator3-1 libatk-wrapper-java-jni libavahi-ui-gtk3-0 libbamf0
  libbamf3-0 libbonoboui2-0 libbrasero-media3-1 libcamel-1.2-29
  libcanberra-gtk-module libcanberra-gtk0 libcanberra-gtk3-0
  libcanberra-gtk3-module libcaribou0 libclutter-1.0-0 libcmis-0.2-0
  libcompizconfig0 libcups2 libcupscgi1 libcupsdriver1 libcupsfilters1
  libcupsimage2 libcupsmime1 libcupsppdc1 libcurl3 libcurl3-gnutls
  libcurl3-nss libdmapsharing-3.0-2 libebackend-1.2-1 libebook-1.2-12
  libecal-1.2-10 libedata-book-1.2-11 libedata-cal-1.2-13
  libedataserver-1.2-15 libedataserverui-3.0-1 libevince3-3 libfarstream-0.1-0
  libfolks-eds25 libfolks-telepathy25 libfolks25 libfreerdp-plugins-standard
  libgail-3-0 libgail-common libgail18 libgconf2-4 libgcr-3-1 libgdata13
  libgdu-gtk0 libgksu2-0 libglade2-0 libgnome-bluetooth8
  libgnome-control-center1 libgnome-desktop-3-2 libgnome-media-profiles-3.0-0
  libgnome2-0 libgnome2-common libgnomecanvas2-0 libgnomekbd7 libgnomeui-0
  libgnomevfs2-0 libgnomevfs2-common libgnutls26 libgoa-1.0-0 libgpod-common
  libgpod4 libgrip0 libgs9 libgssdp-1.0-3 libgtk-3-0 libgtk-3-bin libgtk2-perl
  libgtk2.0-0 libgtk2.0-bin libgtkhex-3-0 libgtkmm-2.4-1c2a libgtkmm-3.0-1
  libgtksourceview-3.0-0 libgtkspell-3-0 libgtkspell0 libgucharmap-2-90-7
  libgupnp-1.0-4 libgupnp-igd-1.0-4 libgweather-3-0 libgweather-common
  libgwibber-gtk2 libido3-0.1-0 libimobiledevice2 libindicator3-7
  libindicator7 liblaunchpad-integration-3.0-1 liblaunchpad-integration1
  libldap-2.4-2 libmetacity-private0 libmusicbrainz3-6 libmutter0
  libnautilus-extension1a libnb-apisupport3-java libnb-ide14-java
  libnb-java5-java libneon27-gnutls libnice10 libnm-gtk0 liboauth0
  liboverlay-scrollbar-0.2-0 liboverlay-scrollbar3-0.2-0 libpam-winbind
  libpanel-applet-4-0 libpeas-1.0-0 libpurple0 libqtbamf1 libqtgconf1 libquvi7
  libraptor2-0 librasqal3 librdf0 libreoffice-base-core libreoffice-calc
  libreoffice-common libreoffice-core libreoffice-draw libreoffice-emailmerge
  libreoffice-gnome libreoffice-gtk libreoffice-help-en-us libreoffice-impress
  libreoffice-math libreoffice-style-human libreoffice-style-tango
  libreoffice-writer librest-0.7-0 librhythmbox-core5 librsvg2-common librtmp0
  libsane-hpaio libslv2-9 libsmbclient libsoup-gnome2.4-1 libsoup2.4-1
  libspectre1 libsvn-java libsvn1 libsvnclientadapter-java
  libswt-gnome-gtk-3-jni libswt-gtk-3-java libswt-gtk-3-jni
  libswt-webkit-gtk-3-jni libsyncdaemon-1.0-1 libtelepathy-farstream2
  libtimezonemap1 libtotem-plparser17 libubuntuoneui-3.0-1 libunique-3.0-0
  libunity-2d-private0 libunity-core-5.0-5 libunity-misc4 libvncserver0
  libvte-2.90-9 libvte9 libwebkitgtk-1.0-0 libwebkitgtk-3.0-0 libwnck-3-0
  libwnck22 libwxgtk2.8-0 libxmlrpc-core-c3 libyelp0 light-themes lynx
  lynx-cur mahjongg metacity metacity-common mousetweaks mplayer2
  mutter-common mythes-en-us nautilus nautilus-sendto nautilus-sendto-empathy
  nautilus-share netbeans network-manager-gnome network-manager-pptp-gnome
  notify-osd ntfs-3g octave3.2 onboard oneconf openjdk-6-jdk openjdk-6-jre
  openjdk-6-jre-headless openjdk-6-jre-lib overlay-scrollbar pidgin
  pidgin-libnotify policykit-1-gnome printer-driver-c2esp
  printer-driver-foo2zjs printer-driver-gutenprint printer-driver-hpcups
  printer-driver-pnm2ppa printer-driver-postscript-hp printer-driver-ptouch
  printer-driver-sag-gdi printer-driver-splix pulseaudio-module-gconf
  python-appindicator python-aptdaemon python-aptdaemon.gtk3widgets
  python-aptdaemon.pkcompat python-compizconfig python-cups python-cupshelpers
  python-gconf python-gmenu python-gnomekeyring python-gtk2 python-ibus
  python-notify python-pycurl python-smbc python-software-properties
  python-ubuntu-sso-client python-ubuntuone-control-panel python-uno
  python-virtkey remmina remmina-plugin-rdp remmina-plugin-vnc rhythmbox
  rhythmbox-mozilla rhythmbox-plugin-cdrecorder rhythmbox-plugin-magnatune
  rhythmbox-plugin-zeitgeist rhythmbox-plugins rhythmbox-ubuntuone
  samba-common-bin seahorse sessioninstaller shotwell simple-scan smbclient
  software-center software-properties-gtk ssh-askpass-gnome subversion
  synaptic system-config-printer-common system-config-printer-gnome
  system-config-printer-udev telepathy-gabble telepathy-haze
  telepathy-indicator telepathy-salut thunderbird thunderbird-globalmenu
  thunderbird-locale-en thunderbird-locale-en-us transmission-gtk
  ubuntu-artwork ubuntu-desktop ubuntu-docs ubuntu-mono ubuntu-sso-client
  ubuntu-sso-client-gtk ubuntuone-client ubuntuone-client-gnome
  ubuntuone-control-panel ubuntuone-installer unity unity-2d unity-2d-panel
  unity-2d-shell unity-2d-spread unity-asset-pool unity-common unity-greeter
  unity-lens-applications unity-scope-video-remote unity-services
  update-manager update-notifier upower usb-creator-gtk vino virtualbox
  virtualbox-dkms virtualbox-qt vlc vlc-nox vlc-plugin-notify vlc-plugin-pulse
  whoopsie winbind wine wine1.4 wine1.4-amd64 wine1.4-common wine1.4-i386:i386
  xdg-user-dirs-gtk xdiagnose xul-ext-ubufox yelp zeitgeist zeitgeist-datahub
  zenity
0 upgraded, 0 newly installed, 467 to remove and 0 not upgraded.
After this operation, 1,807 MB disk space will be freed.
Do you want to continue [Y/n]?
Removing 1.8GB of Ubuntu staff is this right way to go? This is even worse than yesterday when I had to remove qt libraries and everything depending on it (almost every second app with GUI) in order to install VLC player.
I am using Ubuntu 12.04 LTS. Thanks in advance for explanation.
Braiam
  • 69,112
robo
I really don't know what happened to your packages, but try:
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get autoremove
sudo dpkg --configure -a
sudo apt-get install -f
sudo apt-get update
phipsalabim
  • 2,680
Do you have aptitude installed or can you still install it? Aptitude is not going to clean this up in and of itself -- though following its suggestions for fixing broken dependencies will get you back to a working situation. What's more important is that aptitude will likely give you the insight to fix this situation, because of the way it helps track dependencies.
zwets
  • 12,770
  • 37
  • 46
