I want to install Ubuntu on an external USB hard drive (in a blank partition already made in mac) and then use rEFIt to alternate between operating systems.
The problem is that, when running the instalation program (Install Ubuntu 12.10) I am asked the next: "Device for boot loader instalation". And I get the next options:
  • /dev/sda ATA WDC WD3200AAJS-4 (320.1 GB) (Internal)
  • /dev/sda1
  • /dev/sdc WD 5000AAV External (500.1 GB) (External)
  • /dev/sdc1
What option should I select?
Eric Carvalho
  • 55,453
If you only have one partition on the external drive (the one you want for Ubuntu), then go with /dev/sdc WD 5000AAV External (500.1 GB) (External).
