I edited Xorg.conf as suggested here to control the speed of pointer movement for Apple Magic Trackpad in 12.04.1 and it works.
But now the trackpad does not recognize tap-to-click. I read the man page for synaptics but since I am a noob could make much out of it.
Appreciate community help.
First, i located mi synaptics.conf file with:
locate synaptics.conf
Mi file was in:
/usr/share/X11/xorg.conf.d/50-synaptics.conf
I edited my 50-synaptics.conf with:
sudo vim /usr/share/X11/xorg.conf.d/50-synaptics.conf
Finally i changed my original file, from this:
Section "InputClass"
        Identifier "touchpad catchall"
        Driver "synaptics"
        MatchIsTouchpad "on"`
to this:
        Identifier "touchpad catchall"`
        Driver "synaptics"
        Option "TapButton1" "1"
        Option "TapButton2" "2"
        Option "TapButton3" "3"
Gonzalo
  • 61
change this line in your xorg.conf
Option         "TapButton1" "0"
into this:
TapButton(number) sets the mouse event to trigger when you tap your trackpad with (number)fingers. "0" means disabled, "1" means left-click, "2" means middle-click, "3" means right-click.
example
If you want a tap with 2 fingers to be registered as a right-click, set:
Option        "TapButton2" "3"
Alternatively you can delete all three "TapButton" lines from your xorg.conf and the tap-click behaviour should go back to the way it was before.
phipsalabim
  • 2,680
