UPDATED
I tried to learn GParted and use it with all the risks -_- and I think that I found a solution, but I still have problem, please read my question below
this is from terminal after I move the sda7
sudo fdisk -l
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x00075eb1
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 212723711 106258432 7 HPFS/NTFS/exFAT
/dev/sda3 212725758 1953523711 870398977 5 Extended
Partition 3 does not start on physical sector boundary.
/dev/sda5 212725760 410556415 98915328 83 Linux
/dev/sda6 1937899520 1953523711 7812096 82 Linux swap / Solaris
/dev/sda7 410560512 508213247 48826368 83 Linux
/dev/sda8 508216338 1937888819 714836241 7 HPFS/NTFS/exFAT
Partition 8 does not start on physical sector boundary.
Partition table entries are not in disk order
This output is from the terminal before I used GParted
/dev/sda7 410557203 508216274 48829536 83 Linux
Partition 7 does not start on physical sector boundary.
It seems /dev/sda7 fixed(I only tried with 1 partition first since its trial and error lol)
but there's problem with GParted as follows:
Is this normal?
One more question, I know this sounds stupid, but when I tried to resize /dev/sda3, I cant click the label "resize/move".
