The title says it all. I am in a university which has authenticated proxy. Wine is not detecting this. Hence, none of the applications inside wine is getting internet connection. Please help.
I'm struggling with this as well, funnily enough. This is what I've worked out so far:
Wine will grab proxy settings from the environment variable "http_proxy". If you're planning on using the same proxy settings throughout the entire session, you can change the http_proxy variable. Follow these instructions: https://askubuntu.com/a/151047/142903
If, like me, you use the computer on more than one network, one of which has a proxy and one of which doesn't, things get a little trickier. Do all processes inherit environment variables from ~/.bashrc?
NB: You may find it useful to use Gnome or KDE, both of which have graphical interfaces for modifying proxy settings.
Edit #2: After a LOT of digging, I finally found this article on BRAMP.NET describing how to use iptables to redirect all outgoing web traffic on port 80 through a proxy server. The writer mentions that if directly sending the packets to the server doesn't work, it is possible to set up a local proxy server using something like Squid that will point to the network proxy.
This should work for applications that don't respect the http_environment variables. I'm currently working out whether this will still work in 12.04/12.10/13.04, and how to have it done automatically using a script inside /etc/network/if-up.d.
Edit #3: Even more digging has led me to this wonderful post describing how to redirect all system traffic through a SOCKS5 proxy set up by Redsocks - this may be adaptable to suit the current problem.
- 161
Neither setting http_proxy (and HTTP_PROXY) nor using the regedit trick made it work for me. However, using a socksifier helps. Simply install tsocks (or tsocks:i386 in case you have a 32bit wine in use for the program you want to use), configure /etc/tsocks.conf for your proxy server, and export LD_PRELOAD=/usr/lib/libtsocks.so before running wine (e.g. in your .bashrc).
You can check Internet Settings by running:
wine rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl
or Wine Internet Explorer by:
wine iexplore
but I don't think you can change the proxy there, unless you'll try to install the standalone web browser which would support that (e.g. MS IExplorer, Firefox or Opera).
However the workaround is to set-up proxy directly in registry:
wine regedit
and change the key in HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings by setting ProxyEnable to 1 and specifying ProxyServer address.
Or run the following command:
cat << EOF > proxy.reg
Regedit4
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings]
"MigrateProxy"=dword:00000001
"ProxyEnable"=dword:00000001
"ProxyHttp1.1"=dword:00000000
"ProxyServer"="http://ProxyServername:80"
"ProxyOverride"="<local>"
EOF
wine regedit proxy.reg
to set-up automatically (change ProxyServername with appropriate hostname).
Source: How do I configure proxy for IE that runs on Wine? at Quora
- 10,944
As Wine is emulating a Windows environment to let you run Windows application on Linux, this is over the mechanism used by these applications to go to the Internet that you have to look.
Or there is a dedicated set of setting in the application itself to enter the proxy parameters (IP, port, username and password).
Or the application retrieve the proxy settings from the installed and configured Microsoft Internet Explorer. Windows components like Internet Explorer can be installed easily using the winetricks application.
- 7,637
